I'm using StaxRip (the latest beta version) to encode on BootCamp (I have Windows Vista Ultimate SP1 32-bit installed, btw). And for some reason, my encoding will freeze on the at the start of 2nd pass IF the output resolution is for instance 512x384.However, if I encode the output at a higher output resolution such as 624x352 to encode HD, it will encode successfully. I've tried re-installing XviD, VirtualDubMod, AVISynth and installed older versions of StaxRip but nothing will help. I never had this problem on my older PC on Windows XP SP3. I also don't have a problem with this using a different XviD build such as xvid_encraw using MeGUI.
The only way I it SEEMS to work better is when I use an older version of VirtualDubMod, but even then at the end of 2nd pass it will freeze at 99%. If I use the current version of VirtualDubMod, and clear the stats file from another encode, I have found that it works in the same way as an older version of VirtualDubMod would.
I would like to encode successfully, without any crashes!
Results 1 to 13 of 13
I used VirtualDub this time to encode, but it crashed at 100% on 2nd pass, here's the crash log:
Code:VirtualDub crash report -- build 28346 (release) -------------------------------------- Disassembly: 772566a0: c3 ret 772566a1: 07 pop es 772566a2: 0f8571950000 jnz 7725fc19 772566a8: 8d43f8 lea eax, [ebx-08h] 772566ab: 80780705 cmp byte ptr [eax+07h], 05h 772566af: 0f844d950000 jz 7725fc02 772566b5: f640073f test [eax+07h], 3fh 772566b9: 0f8451950000 jz 7725fc10 772566bf: 3bc7 cmp eax, edi 772566c1: 894510 mov [ebp+10h], eax 772566c4: 0f84b9950000 jz 7725fc83 772566ca: 807bff05 cmp byte ptr [ebx-01h], 05h 772566ce: 0f8458950000 jz 7725fc2c 772566d4: 8b4510 mov eax, [ebp+10h] 772566d7: f6400780 test [eax+07h], 80h 772566db: 0f84530e0000 jz 77257534 772566e1: 8bd3 mov edx, ebx 772566e3: 8bce mov ecx, esi 772566e5: e823000000 call 7725670d 772566ea: 84c0 test al, al 772566ec: 0f84420e0000 jz 77257534 772566f2: 803d8003fe7f00 cmp byte ptr [7ffe0380], 00h 772566f9: 0f85ad950000 jnz 7725fcac 772566ff: b001 mov al, 01h 77256701: 5e pop esi 77256702: 5f pop edi 77256703: 5b pop ebx 77256704: 5d pop ebp 77256705: c20c00 ret 000c 77256708: 90 nop 77256709: 90 nop 7725670a: 90 nop 7725670b: 90 nop 7725670c: 90 nop 7725670d: 8bff mov edi, edi 7725670f: 55 push ebp 77256710: 8bec mov ebp, esp 77256712: 83ec28 sub esp, 28h 77256715: 53 push ebx 77256716: 56 push esi 77256717: 57 push edi 77256718: 8d7af8 lea edi, [edx-08h] 7725671b: 807f0705 cmp byte ptr [edi+07h], 05h 7725671f: 0f8415c20100 jz 7727293a 77256725: 8b07 mov eax, [edi] 77256727: 8bf7 mov esi, edi 77256729: c1ee03 shr esi, 03h 7725672c: 33f0 xor esi, eax 7725672e: 333544422b77 xor esi, [772b4244] 77256734: 897dfc mov [ebp-04h], edi 77256737: 33f1 xor esi, ecx 77256739: 8b4604 mov eax, [esi+04h] <-- FAULT 7725673c: 8945f4 mov [ebp-0ch], eax 7725673f: c6470780 mov byte ptr [edi+07h], 80h 77256743: c6470600 mov byte ptr [edi+06h], 00h 77256747: 8b5e08 mov ebx, [esi+08h] 7725674a: 8b4e0c mov ecx, [esi+0ch] 7725674d: 895de0 mov [ebp-20h], ebx 77256750: 83c301 add ebx, 01h 77256753: 894de4 mov [ebp-1ch], ecx 77256756: 83d101 adc ecx, 01h 77256759: 81e3ff7f0000 and ebx, 00007fff 7725675f: 663b5e14 cmp ebx, [esi+14h] 77256763: 0f84b3040000 jz 77256c1c 77256769: 8b45e0 mov eax, [ebp-20h] 7725676c: 8b55e4 mov edx, [ebp-1ch] 7725676f: 0facd010 shrd eax, edx, 10h 77256773: 66894708 mov [edi+08h], ax 77256777: 2b7df4 sub edi, [ebp-0ch] 7725677a: 33c0 xor eax, eax 7725677c: c1ef03 shr edi, 03h 7725677f: 0fa4f810 shld eax, edi, 10h 77256783: c1e710 shl edi, 10h 77256786: c1ea10 shr edx, 10h 77256789: 0bdf or ebx, edi 7725678b: 0bc8 or ecx, eax 7725678d: 8b06 mov eax, [esi] 7725678f: c745f801000000 mov dword ptr [ebp-08h], 00000001 77256796: 8930 mov [eax], esi 77256798: 8b45e0 mov eax, [ebp-20h] 7725679b: 8b55e4 mov edx, [ebp-1ch] 7725679e: 8d db 8dh 7725679f: 7e db 7eh Built on KOS-MOS on Tue Feb 12 22:09:24 2008 using compiler version 1400 Windows 6.0 (Windows Vista x86 build 6002) [Service Pack 2] EAX = 81818181 EBX = 086d4900 ECX = 07f50000 EDX = 086d4900 EBP = 0012deac ESI = b9187969 EDI = 086d48f8 ESP = 0012de78 EIP = 77256739 EFLAGS = 00210286 FPUCW = ffff027f FPUTW = ffffffff Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'ntdll'... ...reading address B918796D. Pointer dumps: EBX 086d4900: 07f500c4 085b72d0 00000000 00000000 00000000 00000000 00000000 00000000 ECX 07f50000: b93dc2a0 0100b47c ffeeffee 00000000 07f80010 07f500a8 07f50000 07f50000 EDX 086d4900: 07f500c4 085b72d0 00000000 00000000 00000000 00000000 00000000 00000000 EDI 086d48f8: 81818181 82824563 07f500c4 085b72d0 00000000 00000000 00000000 00000000 ESP 0012de78: 00000000 07f50000 086d4900 07f56f08 01010118 0012ddc4 00000000 0012df0c 0012de98: 771f99fa 00c1bbdd fffffffe 77257512 086d48f8 0012dec0 772566ea 086d4900 0012deb8: 07f55e00 07f55d40 0012ded4 76529a26 07f50000 00000000 086d48f8 0012df1c 0012ded8: 07e884ca 07f50000 00000000 086d4900 07f55e00 ffffd800 07f55d40 07f563f0 EBP 0012dea8: 086d48f8 0012dec0 772566ea 086d4900 07f55e00 07f55d40 0012ded4 76529a26 0012dec8: 07f50000 00000000 086d48f8 0012df1c 07e884ca 07f50000 00000000 086d4900 0012dee8: 07f55e00 ffffd800 07f55d40 07f563f0 ffffd800 00000002 07f55d40 07f55d40 0012df08: 0012da9c 0012ee10 07e88c20 07eb70f8 ffffffff 07f56600 07e3c448 086d4900 Thread call stack: 77256739: ntdll!RtlFreeHeap [771f0000+66670+c9] 77257512: ntdll!RtlEnumerateGenericTableWithoutSplaying [771f0000+66dc2+750] 772566ea: ntdll!RtlFreeHeap [771f0000+66670+7a] 76529a26: kernel32!HeapFree [764e0000+49a12+14] 07e884ca: xvidcore!xvid_plugin_dump [07e10000+6bff4+c4d6] 07e3c448: xvidcore!xvid_encore [07e10000+2acc8+1780] 07e3b1d0: xvidcore!xvid_encore [07e10000+2acc8+508] 07e3af34: xvidcore!xvid_encore [07e10000+2acc8+26c] 07e3acf9: xvidcore!xvid_encore [07e10000+2acc8+31] 03b37134: xvidvfw!DriverProc [03b30000+6e04+330] 76c999cb: USER32!GetWindowLongA [76c80000+19994+37] 004ab09d: VDProjectUI::WndProc() 004baa3e: VDUIFrame::StaticWndProc() 7646d60f: USP10!ScriptGetCMap [76460000+b3e4+222b] 005a192c: _fputwc_nolock() 005a0b12: _mbtowc_l() 005a192c: _fputwc_nolock() 76c9fd72: USER32!GetWindowLongW [76c80000+1f8bf+4b3] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76c9fdf3: USER32!GetWindowLongW [76c80000+1f8bf+534] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 7646ed0b: USP10!ScriptTextOut [76460000+ea95+276] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76c99d6a: USER32!ReleaseDC [76c80000+19ced+7d] 76c99d75: USER32!ReleaseDC [76c80000+19ced+88] 76c99d75: USER32!ReleaseDC [76c80000+19ced+88] 76c99f8d: USER32!WCSToMBEx [76c80000+19ec1+cc] 76c99f9d: USER32!WCSToMBEx [76c80000+19ec1+dc] 77255dae: ntdll!KiUserCallbackDispatcher [771f0000+65d80+2e] 76c98e7d: USER32!InflateRect [76c80000+18d4f+12e] 76ca06b8: USER32!IsWindow [76c80000+2067b+3d] 76ca03ab: USER32!DispatchMessageW [76c80000+2021c+18f] 7456af85: uxtheme!GetThemeBool [74560000+a886+6ff] 745625a7: uxtheme!000025a7 745625f4: uxtheme!000025f4 76ca0245: USER32!DispatchMessageW [76c80000+2021c+29] 76ca0454: USER32!DefWindowProcW [76c80000+203b4+a0] 76ca041f: USER32!DefWindowProcW [76c80000+203b4+6b] 76ca041f: USER32!DefWindowProcW [76c80000+203b4+6b] 004ba4c3: VDUIFrame::DefProc() 004abaca: VDProjectUI::DubWndProc() 76c999cb: USER32!GetWindowLongA [76c80000+19994+37] 004ab09d: VDProjectUI::WndProc() 004baa3e: VDUIFrame::StaticWndProc() 7723127c: ntdll!RtlImageNtHeader [771f0000+41261+1b] 7725661f: ntdll!RtlAllocateHeap [771f0000+66570+af] 76c9fd72: USER32!GetWindowLongW [76c80000+1f8bf+4b3] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 772566ea: ntdll!RtlFreeHeap [771f0000+66670+7a] 76529a26: kernel32!HeapFree [764e0000+49a12+14] 0058bb72: free() 0058bb91: free() 0058bb91: free() 00483fb3: guiSetTitleW() 0044006c: VDFilterGraphControl::RequeryFormats() 76cb280d: USER32!GetClipboardOwner [76c80000+326ef+11e] 76c99560: USER32!DrawTextExW [76c80000+191ce+392] 76c93c42: USER32!GetWindowDC [76c80000+13ba7+9b] 76ca18ce: USER32!IsDialogMessage [76c80000+21847+87] 76c9fd72: USER32!GetWindowLongW [76c80000+1f8bf+4b3] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76c9fdf3: USER32!GetWindowLongW [76c80000+1f8bf+534] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76ca0943: USER32!CallMsgFilterW [76c80000+20801+142] 76c9f860: USER32!GetClipboardFormatNameA [76c80000+1a552+530e] 76c999bf: USER32!GetWindowLongA [76c80000+19994+2b] 76c999cb: USER32!GetWindowLongA [76c80000+19994+37] 768223a6: MSCTF!TF_GetAppCompatFlags [76820000+2361+45] 00476491: DubStatus::StatusTimerProc() 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76c991ec: USER32!DrawTextExW [76c80000+191ce+1e] 76cb193e: USER32!DrawStateW [76c80000+31825+119] 76cb1955: USER32!DrawStateW [76c80000+31825+130] 76cb20ab: USER32!DrawStateW [76c80000+31825+886] 76cb20bd: USER32!DrawStateW [76c80000+31825+898] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c999bf: USER32!GetWindowLongA [76c80000+19994+2b] 00476575: DubStatus::StatusMainDlgProc() 76c9fd72: USER32!GetWindowLongW [76c80000+1f8bf+4b3] 76c94a0b: USER32!ActivateKeyboardLayout [76c80000+1478c+27f] 76c949c8: USER32!ActivateKeyboardLayout [76c80000+1478c+23c] 76c9495f: USER32!ActivateKeyboardLayout [76c80000+1478c+1d3] 76c94a0b: USER32!ActivateKeyboardLayout [76c80000+1478c+27f] 76ca0b5a: USER32!NotifyWinEvent [76c80000+20b4d+d] 728b6b9f: COMCTL32!_TrackMouseEvent [72870000+35a6e+11131] 76c9fd72: USER32!GetWindowLongW [76c80000+1f8bf+4b3] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76c9fdf3: USER32!GetWindowLongW [76c80000+1f8bf+534] 76c9fea1: USER32!GetWindowLongW [76c80000+1f8bf+5e2] 76c9fe61: USER32!GetWindowLongW [76c80000+1f8bf+5a2] 76ca0943: USER32!CallMsgFilterW [76c80000+20801+142] 0046d842: Dubber::UpdateFrames() 76c98e7d: USER32!InflateRect [76c80000+18d4f+12e] -- End of report -
Wonder if uninstalling Xvid and installing an older version would help. It doesn't crash (just for the sake of argument) if you use a different codec, does it?
Also, not sure about StaxRip, as I don't use it, but if you're just working with stand-alone VirtualDub, maybe AVIDemux would also work.If cameras add ten pounds, why would people want to eat them? -
I tried the last two versions of XviD, but it still crashes. I know XviD is to blame so I don't experience crashing at all with different codecs, like x264.
Which versions? Yeah, I have been suspecting Xvid or how it's interacting, in this case. Did you do a complete uninstall and reboot before installing the other versions?
(Still would like to know if you can do two-pass encoding with ffdshow's version of Xvid... probably can if you tell it to use Xvid's DLLs, but that's not really the point.
I tried the last two, 1.2.1 VAQ and 1.2.1, rebooting in between installs.
It probably wouldn't hurt to try the 1.1 and 1.0 versions, instead - I'm not sure about the 1.2.x versions.
Another good idea, if you have a crash log from VirtualDub, is to run it past Phaeron (VirtualDub's creator) at the VirtualDub forums. He'd probably be better able to tell what the problem is. (Not sure whether he'd allow sending it through email, or whether he'd be willing to take a look at crash logs from forked versions of VD, like VDubMod.)If cameras add ten pounds, why would people want to eat them? -
Hmm... I've been wary of the 1.2.x builds of Xvid, but I can't remember why.
Maybe 1.2 made some changes to the way two-pass encoding is handled, and there's something about it that VirtualDub doesn't like, I don't know.If cameras add ten pounds, why would people want to eat them? -
Kylenol,
Phaeron replied to your post in the Virtualdub Forum. He said that you might try turning off "display encoding status" under XviD, Configuration Settings, Other Options.
Sometimes the status window causes problems. It's annoying having to manually turn it off all the time anyway. -
Unfortuantely, turning off "display encoding status" didn't prevent it from crashing. In addition to what I said earlier about the older build; XviD-1.1.2, I have to say that the opposite is true in the case of a newer build of XviD. When using 1.1.2, it now only crashes if I encode a HD file at 624x352, but will not crash if I encode a 4:3 source at 512x384.
Output size for cropped VOB using Cedocida/VirtualDubMod?
By BeckyD in forum Video ConversionReplies: 1Last Post: 9th Jul 2010, 10:01 -
Change output folder using Scriptwriter for VirtualDubMod?
By midders in forum Video ConversionReplies: 1Last Post: 17th Sep 2009, 21:29 -
VirtualDubMod - Matroska output gets boosted height!
By Gew in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2009, 13:52 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 15:17 -
AutoGK prob - VirtualDubMod crashes on open
By Djinn252 in forum Video ConversionReplies: 8Last Post: 7th Jan 2009, 10:23
