I rarely run into these problems. Got the complete set of a movie. They had 2 mirrors,, and each one, I downloaded just to be safe and came out to be the same totals in size and slices.
Oddly, I had this error in 3 out of the 6 chapters to this series. I was able to play the files, and checked at the very beginning and the very end to see if there was any problem with the player or video playing, and to see if the ending credits got cut off or something and it appears complete to me, but I don't know why I got those errors.
I'm using 7zip, so I don't see a repair option for fixing these RAR files.
Here's a snapshot of the errors. I suppose some would say if it works, then just ignore it, but I'm picky with these being collections, and it just seems strange to get only half of them with these errors, even though the end result is that they all play.
What causes this? What does it mean? How do you fix it?
Does that risk losing anything compared to getting another download set by a different uploader or author somewhere else?
What does it mean "file is broken"?
you'd need a par set to repair the file, assuming they weren't zipped up broken to begin with.
Do you have a tutorial on that ?
I tried to use the repair tool from winrar and it ended up not making a difference. -
Check to see if par files are part of the file download,best to read a tutorial(google) on quickpar and how to use use par files.
There's no par file present from checking. I guess I have to dump this.
A better way I suppose is to just get any video files and get subtitles separately, instead of trying to find one with hardcoded subs.
Is there a thread here on looking up subtitles that match the video source or configuring it so that it is synced through a standalone dvd player that can read subtitle files? -
And I tried a so-called Rar Recovery Toolkit (not the one you mentioned), but it also did nothing . . . at least on the files I was trying to fix. That is a downside of using RAR. If you had an alternate download source, that might be your best bet.Originally Posted by mike69Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
My DVD Authoring software stopped working and had an "APPCRASH" error
By Blueknight in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2011, 22:55 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
Audio software that "overrides" default file-types/icons
By djdust in forum Software PlayingReplies: 0Last Post: 15th Apr 2011, 03:09 -
"This AVI file is broken."
By timmer545 in forum Video ConversionReplies: 10Last Post: 31st Oct 2007, 07:02 -
AVI file "broken" when played with VLC
By Salva Veritate in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2007, 12:01
