Dear all
I have been using the latest AVIDEMUX for a month now, mainly to cut and join 640*480 FLV files. The problem is that I have to start every new clip or cut with an (I) frame, otherwise the previous or the following frames would be broken causing alot of blocking in the final video.
I would spend a lot of time in trying to get to these (I) frames by pressing the right or let arrow key and if I press longer I might miss the (I) frame then I had to go back and move the frames one by one until I reach the (I) frame.
Is there another easy way to get to these (I) frames or is there another free software that does the job easliy? I wish the authors of this excellent program could come up with some thing.
My thanks for any contribution.
You can navigate on keyframes by using the "<<" and ">>" buttons on the GUIOriginally Posted by shaema
Dear Poisondeathray
Thanks very much for proving that I have been shortsighted and stupid!
I hope I will be more careful next time!
Cutting a flv in Virtualdub - audio synch problems
By Faufiffon in forum Video ConversionReplies: 3Last Post: 1st Sep 2011, 14:49 -
newbie Q about cutting data from flv
By edurbrow in forum Newbie / General discussionsReplies: 5Last Post: 11th Jun 2011, 19:09 -
Splitting/cutting FLV
By optofonic in forum EditingReplies: 10Last Post: 16th Oct 2010, 16:28 -
Tools for Cutting and Merging FLV Files
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 11th Feb 2009, 19:48 -
Multiple FLV files into 1 big FLV file, how??
By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 15:11
