Hello,
I just got the HF200 and it has 2 modes for recording in 1080P, FXP and MXP. I was just curious as to what exactly the differences where and if it worth it to actually use MXP over FXP, which I believe is supposed to be better, but someone at a site, can't remember the site said that you might as well just use FXP.
Yeah that part I got because it says it on the camera, but being a noob, I was looking for a bit deeper of an explanation.
Thanks -
Higher bitrate means not as lossy, and generally better quality
But the sensor/imager/lens on consumer level camcorders isn't that great, so the visible quality differences aren't that great between the 2 modes. Using a higher quality camcorder like HMC150 for example, you can tell the differences more easily between 17Mbps and 24Mbps. Still I would use MXP if you can afford it (in terms of shooting time)
Similiar camcorders with Canon Vixia HV20
By 1234567 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Oct 2011, 22:23 -
MXP speed vs FXP
By Ematte in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Apr 2011, 15:04 -
CANON T2i: Noisy AF in Movie Mode
By taboo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Apr 2011, 21:18 -
Several questions about "pass through" and Sony/Canon camcorders
By tadd5181 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 9th May 2010, 13:42 -
Question regarding using Canon HV20 in SD mode
By m_ahlenius in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 30th Dec 2007, 17:49
