    Oct 2008
    Russian Federation
    Please help!
    I have dual-audio mkv file and by default haali media splitter select first track, so when I use script
    directshowsorce(file.mkv)
    I only rich the first track. Is it possible to select second, third, ... audio track from ogg/mkv/mp4 files to be using avisynth?
  2. I don't think so, at least not with DirectShowSource(). You can remux the mkv with mkvmerge to have 1 audio track, or extract the audio and load it separately
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You could try FFmpegSource:
    FFmpegSource(string source, int vtrack = -1, int atrack = -2, string timecodes, bool vcache = true, string vcachefile, string acachefile, string pp, int ppquality = 6, int threads = -1, int seekmode = 1)
    Try different values of atrack:
    atrack & vtrack: Track number as seen by the relevant demuxer, starts from 0, -1 means it will pick the first suitable track and -2 means it's disabled.
    Oct 2008
    Russian Federation
    Thanks a lot for your suggestion!
    Oh, I do not know why I could not start ffmpegsource, it says there is no such function or so on. But ffmpegsource2 works fine.
    FFMPegSource2("<>.mkv", vtrack = -1, atrack = 2)
    selects second audio track.
    ffmpegsource2 looks very promising, thanks for suggesting it again.
    (poisondeathray, thanks too, but I already know about demuxing)
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Both versions are plugins, not built-in functions. You must have installed ffmpegsource2 (by putting the dll in the plugins folder) previously.
    Oct 2008
    Russian Federation
    Yep, but is ffms2 is newer version or something completely different? Is it better or worse?
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Pretty sure it's just version 2 of the same project, but haven't followed the history.
  8. Yes it's a newer version that replaces the old ffmpegsource. It has updated libraries and some new functionality. Read the documenation for more info
