All,
Need some advice how to fix an out of synch AVCHD file. I recorded 2 AVCHD (*.ts) files both 45 minutes each using my Hauppaugge HD PVR 1212 unit. The second file is fine. In the first file, the first 10 minutes are perfect, but the final 35 minutes are off by about 3 seconds with the audio trailing the video. I have edited the file and cut out commercials with TSPE and isolated the section of the file that has "drfited" by itself. With MPEG2 files I could demux and realign video/audio with Womble MPEG Video Wizard and then save new muxed file. Which tools can I use to do the same with AVCHD and re-synch the file the way it should be? Thanks.
AVCHD FILE output
By photom4n in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2011, 18:57 -
4.37gb mkv file to avchd
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 12th May 2010, 14:12 -
Subs out of synch with iso file
By migrantwing in forum SubtitleReplies: 0Last Post: 18th Apr 2010, 19:13 -
AVCHD audio and video are out of synch
By edong in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Jul 2009, 01:55 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47
