hello,
i have on my PC a folder of a Blu-ray movie.
these are the folders i have:
BDMV
CERTIFICATE
SLY!
the total size is about 39 GB.
how can i play it from my PC ? i tried using COREL windvd 2010 --> open from folder.
but nothing...
is there any other way to open it ?
Thanks.
TotalMedia Theatre 3 will play the folder,better than windvd and pdvd.
You should also be able to play the individual .m2ts files in the BDMV/STREAM folder with MPC-HC or ZoomPlayer, or a few other players. Usually the largest .m2ts file is the main movie, but some BDs split that over several .m2ts files. TM3 is a bit expensive just for playback of a ripped BD unless you plan to use it for BD disc playback also.
hmm..
well i want to enjoy all the futures of the blu-ray. whice include the menu. changing the language , or sound. and ect..
if i just play the m2ts file it will play the movie alone..
BDMV Folder from fullhd camcorder can not play with Blu-ray player.
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th May 2012, 04:57 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Riped blu ray movi to blu ray folder.
By macisen85 in forum Blu-ray RippingReplies: 0Last Post: 22nd Oct 2011, 06:24 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
How can we Copy and then Play Blu-Ray´s Discs from our hard drive(Folder)?
By jjulio1 in forum Blu-ray RippingReplies: 4Last Post: 22nd Apr 2010, 12:18
