    Feb 2002
    CANADA
    I use Nero to burn my Video CD's which works better then anyother burning program out there.
    that is if its an mpeg. file,
    when i use a avi. file movie and encode it with Nero
    I get a trob like distortion every 2 seconds. which makes the movie unwatchable. if i use TMPGnc to encode the movie it says it cannt cuz it was compressed audio. and if i try to decompress it, it says it can read it.
    i get this with all avi. file movies.
    is there anyone out there that knows the best way to get a avi. file on a VCD??
    thank you so much for taking the time to read this.
  2. As far as I am aware...... you would need to redo your avi files to a VCD compliant mpeg. I have been trying to do this as I wish to convert some DivX to vcd. Problem I have is after using Virtual Dub to create audio file, TMPGenc will not accept the avi file from the DIVX disk.
    if you have a look at the column on the left
    'HOW TO'
    'CONVERT'
    there is some info and tools for converting AVI to MPEG. Give it a go, am still trying myself
    Totally agree with NERO it does seem to be the best!
    Not sure if it's been any help.
