I've haven't had a problem before but now i put in avi files like normal and hit convert. It goes through the process of converting and burning. when done i looked at dvd and it shows that something was writing on dvd but won't play on computer or dvd player and that'never happened Please help
Let me look into my crystal ball . . . . .
Nope. Nothing.
Maybe is you start again, slowly.
What software are you using to create the DVD ?
What software are you using to burn the disc ?
What media are you using ?
Give us something to work with, rather than having to guess at everything.Read my blog here.
sorry like that's why i'm in newbie section
using convertxtodvd to convert and burn.
TDK dvd-r
please help thank you -
Try this
Use ConvertXtoDVD to create a folder. Do not use it to burn.
Use Imgburn to burn your DVD to a disc.
Consider getting better discs, as TDK tend to be very hit and miss quality wise.
There have been a couple of reports of issues with the built-in burning application in ConvertXtoDVD in the current version. It may be related to that.Read my blog here.
thank you thank you very much i really appreciate it i will try this right now
LG FB162 DVD playing problem
By max_vini_vidi_vici in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th Jun 2011, 21:01 -
DVD Playing Problem
By Elevenius in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 01:42 -
Problem playing DVD
By kevinlane in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2011, 07:49 -
Problem with playing a DVD
By BS82 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 6th Jan 2010, 14:03 -
DVD playing problem
By airwolfUK in forum Newbie / General discussionsReplies: 4Last Post: 24th Aug 2007, 04:19
