    Aug 2002
    South Florida
    The playback option, in VLC, does not have a loop option. How can this be achieved? This should simple selection-but.
    Press L on your keyboard or View->advanced controls and click on loop from a to b-button .
    Aug 2002
    South Florida
    I tried the A,B thing before, and it does not work on my machine. I started the clip and pressed A, then go to end to press B. If I go to the very end, it exits the program. I tried other combinations-no soap. This is not a good system-a simple repeat would have been much better than this obfuscation. Perhaps, GOM Player is better.
    Just used GOM and no problem-it works.
    Oct 2010
    SK, Canada
    An older thread but maybe this could help some people with the same problem.
    In your VLC player....
    tools....preferences....show settings "all"....playlist....repeat current item....save
    Some use the repeat all but I prefer the repeat current item. Hope this helps.
