    Feb 2002
    Porto Alegre, Brazil
    I use the card to capture mainly from vhs tapes. So recently the image from vhs tapes has been appeared distorted. Itīs like the source image from the tape split in two layers one on the botton is the source but the up layer is like a white distorted screen that flicks. It s only happend when the playback is used because when a use the antenna through the vcr and the composite of AIW128pro it goes well the image is perfect( so the cables are good ) . It happends in all vhs tapes also in the ones that was fine some days ago. Well I change the vcr too and the problem persists . How can it be fixed ?
    Dec 2001
    USA
    ATI AIW's have macrovision detection, which is to stop you from recording prerecorded movies. Most prerecorded tapes and DVD have macrovision protection on them, There is a program out to disable the macrovision detection on ATI AIW.
    Feb 2002
    I think it was the problem but why didnīt happenī before ?
