Whenever i try to split up a large mpeg1 file (over 1gb)with MyFlix 2 i have probs searching the exact cut point as i canīt fast forward the video. If i pick a certain point, it wonīt start to play again which makes it very hard for me to cut my live show and not cutting the songs itself.... I also noticed that Windows Media Player got the same prob: As soon as you change the position "manually" it wonīt be able to play the video. But both (MyFlix and MediaPlayer) work fine with smaller files (about 300mb). Is there any solution to this problem? Thx very much for your help.....
CU
nothingnet
I might be wrong, since I haven't read anything lately about it on the forum, but when you encode to VCD/SVCD, you should check the box in TMPGEnc that says "Create bitstream for editing."
Cutting HD files
By surfer in forum EditingReplies: 2Last Post: 23rd Jan 2010, 14:06 -
Cutting sections of HD files
By Fire Foxer in forum EditingReplies: 10Last Post: 29th Nov 2009, 12:21 -
cutting FLV files
By shaema in forum EditingReplies: 2Last Post: 24th Sep 2009, 12:01 -
Cutting VOB files
By DELTAsnake in forum EditingReplies: 20Last Post: 6th Apr 2008, 17:23 -
trimming and cutting up long AVI's
By blackice in forum MacReplies: 4Last Post: 30th Sep 2007, 09:57
