Alltoavi can convert mkv to xvid, but it also auto compresses down to 55% of the original video(1.4 gb). This really compromises the quality. Is the another progam that can convert mkv to avi, xvid w/o compressing. Thank you.
				Results 1 to 10 of 10
	The only way you can avoid re-compressing is if the video in the .mkv is already xvid/divx. Otherwise, no choice. You can use mkvextract to extract the audio and video to put in an .avi container. Use mediainfo to find out the audio/video codecs in use in the .mkv. Have a good one,
 neomaine
 NEW! VideoHelp.com F@H team 166011!
 http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
 Folding@Home FAQ and download: http://folding.stanford.edu/
	Are you sure it doesn't allow you to specify a filesize or bitrate? What kind of converter is that?
	Thanks for all responses. 1/ I fed a 81mb xvid file into alltoavi, set video bitrate at 1000 (maximum), also xvid for the output. the out put was compressed down to 55mb. I think alltoavi is only good to convert dvd to avi knowing that some video quality will be lost.
 2/ I tried handbrake and the output is pretty much similar(the output is smaller)- still loose video quality I believe.
 I will try mkvextract to extract video and audio. which software will be best to remux them to avi file?
	inorder to avoid compression and maintain the video quality what bitrate has to be?
	An alternate solution, though not as simple as a "One Button" approach, can be found at
 http://anime.nickistre.net/blog_entry/anime/2007/03/03/mkv_h_264_codec_to_avi_xvid_codec_conversion
 Although it does take longer, is more complex, and addresses MKV files that use h264 video, it can be adapted for just about any type of video stream. I've had excellent results using that method.
	Set a higher bitrate or set a higher quality.Originally Posted by volam1
  How to convert MKV to AVI or OGM to AVI using mencoderBy Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  How to convert matroska MKV to AVI or OGM to AVIBy Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 01:56
  Convert AVI (miniDV) to MKV/MP4, large files only convert partiallyBy Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44
  Best way to convert mkv to avi?By dporvin in forum MacReplies: 17Last Post: 27th Mar 2010, 15:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
