How do you use ccextractor for mac? I know virtually nothing about the terminal, so I have NO CLUE what I'm doing.
In all honesty I'd say give up if you're not familiar with the command line. Really. What I'm going to say will make very little sense.
That said, if you have the Developer Tools installed it does compile easily. I couldn't work from /mac/build.command so I opened it in TextEdit and copied it to the clipboard, cd'd to the src directory, pasted it in to the Terminal and ran it. That produced an executable named ccextractor. Running that with:
produced a very long list of options which I won't paste here. There is a GUI for the Windows version so I'd advise you to use that or ask a Windows-using friend.Code:./ccextractor
Extracting closed captioning from DVD with CCExtractor?
By ecc in forum SubtitleReplies: 17Last Post: 6th Apr 2012, 14:10 -
Problem using CCExtractor 0.55 on one certain file ...
By epstewart in forum SubtitleReplies: 2Last Post: 8th Jul 2010, 15:28 -
ccextractor DVB-T Subtitle rip
By raketten in forum SubtitleReplies: 1Last Post: 7th Mar 2009, 11:59 -
NEW VERSION: ccextractor
By ccguy in forum Latest Video NewsReplies: 0Last Post: 15th Jun 2008, 12:37 -
ccextractor timing issues
By Neisse in forum SubtitleReplies: 23Last Post: 16th May 2008, 09:23
