    Aug 2009
    Planet Earth
    Does this program work mkvmerge GUI ?
    want to explain the pictures
    how splitter mkv???
    DO you want to cut a mkv or what?
    http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#global_split
    Aug 2009
    Planet Earth
    yes
    You can also use avidemux to edit mkvs.
    Aug 2009
    Planet Earth
    cut mkv to mkv or avi
  6. U can use tsmuxer(Demux) to cut mkv files from start to ending time. Just convert times to seconds to cut your mkv into individual files, then all the files can be joined using mkvMerge(add+append)...
