I have looked around the web to no end before asking anyone anything. But have not found program that will automaticly remove duplicate frames from an avi encoded in divx. I didnt encode this avi so I cant do it over or anything like that. I wouldnt mind doing it by hand except that the avi has some 190,000 frames. About every 10 frames is 2 dup frames of the 10th frame , so it makes the avi look like its studdering. I used Vdub to see this in action my self frame by frame. And Did a lil testing deleting the 2 dup frames after every 10th and all the studdering stoped.... Now if someone could some how tell me of a program that could remove dup frames automaticly that would be grate. =)
btw Im new here so go easy on me =p
Donald Grafts avisynth package "Decomb" does this, and many more things. I think there's also a Virtual Dub version of this filter. The command for deleting frames is Decimate(cycle=n), in your case n=10.
Go and check it out at http://sauron.mordor.net/dgraft/ -
Ok thanx, sounds good. I checked out the web page , has some good stuff, the link he has to getting that tool is down right now but Ill try agin..
Decimate odd patterned duplicate frames in video
By raphaelt in forum Video ConversionReplies: 2Last Post: 2nd Feb 2011, 23:57 -
Remove Duplicate Frames
By robindean in forum Video ConversionReplies: 26Last Post: 11th Mar 2010, 16:30 -
Frame blended and duplicate frames
By loekverhees in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jan 2010, 10:35 -
duplicate frames
By qscesz in forum EditingReplies: 5Last Post: 25th Feb 2008, 12:56 -
Can I decimate duplicate frames to get 23.976
By MagicSparky in forum Video ConversionReplies: 5Last Post: 21st Feb 2008, 16:26
