I have a DVD that I use for a class I teach. It is an original, but it is old, and I think it was created poorly from a VHS original (not sure).
When I play the DVD on any of my TVs (using multiple DVD players), the sound is terrible! You can't hear it, even with the volume all the way up.
When I play it in the computer, using VLC, it works just fine.
I really need this to work in a regular DVD player. I could also work with it if I had it in AVI format, as I have and Iomega ScreenPlay Pro. Is there some way I can bring the volume up, or do something to fix it?
Thanks!
Try convert it to avi with mp3, use for example autogk, handbrake. If the audio is still low in the avi mp3 just run https://forum.videohelp.com/topic314909.html
I had a similar problem but I was using a multi scart when I unplugged the VCR and sat from the multi scart the volume skyrocketed and I was estatic!
Try using a direct connection between tv and dvd if u aint already.
U could try converting the vids using Super video converter and increase the DB output in the conversion options -
Demux the DVD, to get separate video and audio files.
Boost the volume of the AC3 audio using the method here: https://forum.videohelp.com/topic317891.html
Reauthor.
The video will look exactly the same.
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 17:06 -
Some MKVs cause MPC HC to flicker but play fine with VLC. Help please?
By elcoyoteloco in forum Software PlayingReplies: 2Last Post: 6th Nov 2011, 23:42 -
VLC: always maximises volume?
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 11th Oct 2011, 12:06 -
DVD footage with low volume CAN WE FIX IT ??
By rockonvidtrade in forum AudioReplies: 7Last Post: 11th Jan 2010, 12:27 -
'jerky' .avi in QT but fine in VLC player?
By rotuts in forum MacReplies: 9Last Post: 5th May 2008, 13:07
