Closed Thread
  1. Last edited by cybershot; 10th Oct 2010 at 21:19.
  2. What codec did you use in virtualdub when saving the avi?.
  3. p p
  4. It may be saving it out as a mpeg. Not sure, i know that h264 will make it much smaller though. That i know of, virtualdub can not use the h264 codec. You can use quicktime pro. Or install the x264 codec and use megui. You do need the .net frameworks. There should be some guides here for that.
  5. Originally Posted by cybershot
    I'm not sure which one it was?
    File>Save as AVI
    You probably haven't chosen a codec, so it saved as uncompressed video. Go to Video > Compression and choose XviD or something. Or download x264vfw, which will allow you to select x264 in VirtualDub.
    Why are you resizing to 16:9 and 1280x720 anyway? Your video isn't high def, and that's not the right aspect ratio.
  6. p p
  7. p p
  8. I'm a Super Moderator johns0's Avatar
    canada
    Closing this thread due to op editing his/her own threads with nonsense.
