Hi i am trying to install arabic subtitle into the dvd but it gives me a japanese characters instead of arab even if i made it the subtitle 2 arab still gives me the japanese letters help
Have you tried setting the font to Arial Unicode?
Also, make sure you have support for right to left text and complex characters enabled in your "Regional Settings" in the control panel. -
Most Windows subtitle programs are NOT Unicode aware. So that means that you have to go to the Control Panel -> Date, Time, Language and Regional Options -> Regional and Language Options -> Advanced and then where it says "Select a language to match the language version of the non-Unicode programs you want to use", you have to pick from a list one that matches your language. Reboot. Hope it fixes the problem (it may not). Be aware that doing this may cause some programs on your PC to act funny or display garbage characters like above, but it also might fix the TMPGenc issue.
Hello, sorry it did nt fix the problem it showed japanese characters instead
Then there probably is no solution for your problem. You might write to the author and ask for help. That definitely should not have happened with a properly written program.Originally Posted by FAHAD9225
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 11:45 -
TMPGEnc DVD Author 3 cuts off subtitle text
By headless chicken in forum Authoring (DVD)Replies: 8Last Post: 8th May 2010, 05:49 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
TMPGEnc DVD Author 3 no longer read .TS files?
By Nick Burns in forum Authoring (DVD)Replies: 3Last Post: 5th Nov 2007, 01:28
