Hi
Just replaced my processor with a newer one, and when I click properties in my computer then I can see under computer only : AMD Processor model unknown. Why I get model unknown?
Did I do something wrong?
if you boot into the motherboard bios is the cpu identified there?
How do I update the motherboard bios?
By the way, even in BIOS the processor is still unknown model -
get the latest bios from the motherboard man. web site. follow the instructions very carefully. after it's installed, re-boot back into the bios and "load safe defaults" or power off and clear cmos, before booting back into windows.
are you sure the cpu you installed is supported for the motherboard you installed it in? again you can get at the m.b. man. web site.--
The easiest way to update your bios is put it on a usb flash stick and reboot and choose to update bios in the bios menu,might have to hit alt+f2 or similar when booting and choose the usb dir,check with your mb manual if your mb supports flashing this way.
If you dont update the bios or there is no bios update then you might have problems running the cpu with the mb,i had to replace my mb when i installed my phenom ii,said unknown processor and windows would freeze.I think,therefore i am a hamster.
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
Which Processor for my HTPC
By Bronx in forum Media Center PC / MediaCentersReplies: 4Last Post: 20th Oct 2010, 14:54 -
What processor should I buy?
By bagmand22 in forum ComputerReplies: 5Last Post: 22nd Dec 2009, 07:33 -
Is it my processor?
By davej1983 in forum Software PlayingReplies: 7Last Post: 11th Jan 2009, 01:53 -
Processor
By Tom in HD in forum MacReplies: 1Last Post: 1st Dec 2007, 22:02
