Hi everyone,
I have captured videos trough my Camcorder but the audio is too noisy.
So I captured the audio with my Tuner and that's less noisy.
The Audio format is the same as the DV AVI (PCM uncompressed) the only thing different is, it's splitted.
I thought this would be easy, just replace the audio and then let VirtualDUb do the rest (with changing framerate)
But it isn't working that way.
There should be few things you should now,
1. The original DV AVI is also out of sync but VirtualDUB does the job.
2. I've tried changing the framerate of the original DV AVI with Vdub and manually match the audio in Vegas but that also doesn't work.
Im struggeling the whole day with this problem I can't find a solution
	The flag once raised will never fall!
	If you couldn't get it in sync in vegas, you probably have dropouts or missing video or audio sections. If this is the case it will never match by just lining them up. You could add silence or blank audio to sections until it matches
 What does this mean? The original audio is out of sync?1. The original DV AVI is also out of sync but VirtualDUB does the job.
 Why don't you just capture from your camcorder with windv or vegas? And if the audio is too noisy, process with some noise reduction filters.
	I thought capturing with firewire was digital?
 So I used Windows Movie Maker.
 What's the difference between WinDV/Vegas and Moviemaker?
 I've used WinDV earlier but then I changed to moviemaker cause I could schedule in Moviemaker.
 I've tried Adobe Audition with nois filters but I dont like the result.The flag once raised will never fall!
	I want to sync lips if that's the term.
 The audio can start the same in the beginning but later it's just a bit out of sync.The flag once raised will never fall!
  audio sync problem, how to work out progressive audio sync delayBy jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09
  MKVvextract stretches extracted audio/Audio not in sync with videoBy cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15
  How to sync the dubbed audio to make a dual audio .aviBy Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17
  An app to visually sync audio to video similar to Subtitle Edit visual syncBy cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54
  SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvidBy dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
