Some of the DivX files I came across on the web when I load them into
tmpgenc or virtualdub the audio is not recognised. .
I can play the divx and hear it on the computer because I installed
these ...
Iviaudio.ax and Mpgaudio.ax
Is there any way to rescue the avi's so I can put them as
NTSC VCD or SVCD ?
8) I'd it like too.
I've got a DIVx (Oceans 11) with Kristal codec & AC3, with the codec intalled. I can see & hear the AVI w/ WMP, but VDub (1.4D) can't recognize the correct audio codec, and old version of TMPGenc (12i) can read the the audio but the result WAV or MPG (audio part) is very bad.
If any has any solution / tool to decode AVI (audio) to WAV ???????Miguelo Perez
Argentina -
I'm far from an expert on the topic, but I ran into this problem yesterday (a film of a Diary) and what I did was that I exported the avi-sound to a wav with Virtualdub, and then used that wav as the Audio source in TMPEGENC when I encoded it to VCD, worked fine. Maybe there is a simpler solution (the wav weighs in at 1gb+, but it took only 10mins on my Celeron 466 to export, so that is almost nothing compared to the encoding) at hand... But it's a startingpoint for you anyways.
HTH"The future is no longer what it used to be" -
So your asking how to convert the sound from an avi with ac3. The are number of ways, but the method that i find easyest is:
The new Tmpgenc ver 2.52 has improved Direct Show reader, so if you give this highest priority, at 2 or so. You need to have Direct Show ac3 filter installed. If you install Nimo codex pack and under Direct Show filters mark of the ac3 filter. Know you just have to load the avi source in Tmpgenc, but do not try any external audio decoders.
Problems: If you experience that the sound is constantly out of sync, use BBmpeg to multiplex the mpv and mp2 files, and delay either the sound or movie
Hope it helps
frotse
How to convert MKV Matroska to Avi or Divx including audio tracks and sub
By s.elmagnifico in forum User guidesReplies: 0Last Post: 16th Aug 2008, 09:47 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 18:22 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 16:51 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 09:33
