    Oct 2007
    Neverland
    I have got two questions regarding Adobe Encore 2.0.
    1. Is there any way to create a new project in which I can import custom size movies? Like 640 by 480?
    2. When I import a (randomly choosen) movie clip of 350MB, Encore says the output is 1,26GB! How's that?
    Is there any way the output file can be a lot smaller, or at least something like 750 MB...
    Oct 2005
    666th portal
    dvd spec is 720x480 ntsc or 720x576 for pal and it's got to be mpeg-2. basically anything else needs re-encoding. file size depends on bitrate.
    read "what is dvd" the link is on the page in the upper left corner.
    Oct 2007
    Neverland
    okay thanks, so there is no way Encore will let you use a custom size movie file like 640x480? then I'll have to convert it to 720x576.
