Hello.
Iv a couple of question regarding the best output format using an AVI file produced in Aftereffect 6,
1) Im looking first of all for a WMV freindly format with as little loss in quality as possible end file size would need to around 600 mega bytes---origina; file avi is 1.6 Gig.and would that be ntscor pal.
2) Same as Question 1 initally except this time the final format needs to be on dvd to play on television Europe,best quality again with a final file size of aroud 600 mega bytes---NTSC or Pal
Pete
Please give us as much information as possible
How long is the clip? The source file size doesn't say anything
WHat is the frame size/resolution and framerate?
1)Convert to wmv then. Use WMVMuxer and use 2-pass encoding. Calculate the average bitrate using a bitrate calculator.
2) Convert to dvd mpeg using a good encoder like hcenc(or with a gui for it like avstodvd). -
hi,
thanks for answering
File length is 45 second-----resolution is 72 ----frame ate is 30 fps----
Hrame size is 768x576 -
Then can you shrink it to much smaller than 600Mbytes and still keeep very good quality. Try the above and encoders and use the highest possible quality settings/profiles.
Mr Baldrick I thank you.
So the avi resolution was OK then ?and do you have any recomendations for converting AVI to WMv with little quality loss.all I have is the normal run of the mill convertor,and the qualiy is quite por.
Robert
How do I take .avi or.mp4 files and put them on a video DVD?
By TripleH in forum Newbie / General discussionsReplies: 6Last Post: 5th Sep 2009, 10:05 -
Put many avi files onto DVD
By Airjrdn in forum Authoring (DVD)Replies: 8Last Post: 23rd Apr 2009, 22:45 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 20:32 -
Can I Put Video Files And Picture Files On Same Disc?
By Lennoxtown in forum Video ConversionReplies: 3Last Post: 29th Dec 2007, 06:05 -
where to put the MAQ files
By the posse in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 10:52
