I had an MKV (HD 720p) file that I converted to a PS3 compatible MP4 using GOTSent, also using the splitting into 4GB files option. This worked fine and the two resulting MP4 files were easily playable on my PC.
However, when transferring them to my PS3, the second file was labelled as corrupt. To try and fix this, I tried using YAMB to demux the h264 and aac streams from it. But, this is the error message I have been receiving:
I have searched around for solutions to this but have found none. Unfortunately, I do not possess the original MKV file anymore.Code:[22:24:41] : Yamb 2.1.0.0 beta 2 started !!! [22:24:41] : OS type detection...Windows XP Professional x86 (version 5.1, Build 2600 : Service Pack 2) [22:24:41] : MP4Box found... C:\Documents and Settings\*******\Application Data\Yamb\MP4Box.exe [22:24:41] : MKVextract found...c:\documents and settings\*******\application data\yamb\mkvextract\mkvextract.exe [22:24:41] : EAC3to found...c:\documents and settings\*******\application data\yamb\eac3to\eac3to.exe [22:24:48] : File.mp4 loaded.... [22:24:51] : Extraction of Video Stream from File.mp4... [22:24:51] : Command Line used for extraction : "C:\Documents and Settings\*******\Application Data\Yamb\MP4Box.exe" -raw 2 "E:\Folder\File.mp4" [22:24:51] : File saved in E:\Folder\ [22:24:52] : Error opening file E:\Folder\File.mp4: IsoMedia File is truncated [22:24:52] : [22:24:52] : Total Time Elapsed...01 secs [22:24:56] : Yamb 2.1.0.0 beta 2 closed.
Any solutions?
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 19:35 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
h264 - IsoMedia File is truncated
By HoraceX in forum Video ConversionReplies: 1Last Post: 22nd Nov 2008, 19:53 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
