    Oct 2008
    Hi.
    I Use ConvertXtoDVD to convert and burn downloads. And for some reason When the burn process starts. It fails strait away.
    Anyone got any ideas why this is happening?
    Has it ever worked?
    Does it work to burn fine with other burning application?
    And this is not advanced video conversion. Moving you.
  3. Member Seeker47's Avatar
    Jul 2005
    Originally Posted by Baldrick
    Has it ever worked?
    I had an example yesterday that happens here with ConvertX, from time to time.
    The conversion takes place, but there is no burn. The error line in the log may
    vary, but is typically along the lines of "Could not set DAO write parameters,
    Code 5." (or was it SAO ?) I'll try to make a more exact note of it in the future.
    When this has occurred, I've always been able to take the VIDEO_TS folder from
    the CX2D job and burn it with IMGBURN. The results from that are fine. But the
    CX2D mystery remains. I'm using ver. 3.6.4.158, but have seen this with several
    previous versions as well.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
