I have a Canon HF100 AVCHD camcorder that produces excellent picture quality, and when I edit the video from it, if I render back to AVC format using Vegas I can tell the loss of quality. The camera came with the Pixela Imagemixer program, which is an abomination as far as the editing process goes, but it does one thing excellently and far better than any pro NLE, which is producing a mostly untouched AVCHD video which has only been recompressed a few frames around cuts, since you can do more or less frame accurate editing with it. But the video quality is still as perfect as when watching the footage from the camera itself connected to the TV set.
Are there any other options as far as frame cutters go, to edit AVCHD mts or m2ts files, even if they don't allow frame accurate editing, but that don't re-encode the video in any way, and are rather easy to use? I'm talking something simple like VirtualDub with a plugin or something. I know there was something like this some time ago but I remember trying it and it didn't work.
Most will cut on I frames which means half second cut points.
http://www.kiva.org/about
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
AVCHD frame rate help.
By Rii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 13th Aug 2010, 22:11 -
Cut AVCHD not aligned at the frame boundary
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2010, 22:54 -
AVCHD MTS Cutter
By cheerful in forum EditingReplies: 11Last Post: 25th Jan 2010, 21:58 -
Lossless h.264 or avchd cutter
By yardline in forum Video ConversionReplies: 2Last Post: 4th Oct 2008, 11:21
