I just read the - How to convert a VCD(DAT) to a mpg - guide on this web site.
http://www.vcdhelp.com/convertdat.htm
One thing the guide fails to mention is this, just what exactly is the difference between a fully compliant VCD mpeg file and the .dat file on an actual VCD disc? This leads me into the following two questions:
1.) Why not just rename the .dat file to .mpg?
2.) Is there any quality loss in converting the .dat file to a .mpg file of VCD specs using the software mentioned in the guide?
Thus far I have archived my vcd compliant mpg files to cd using VCD format, resulting in the .dat file. I assumed that this file was basically the same as a mpg file. The existance of the guide suggests that I am wrong and that there is a difference between the .dat file on a vcd and an mpg file of vcd specifications. Which leads me back to my primary questions, what is the difference and why would I want to convert my .dat file back to .mpg with software as opposed to just changing the file extension to .mpg?
Thank you
There is a difference. I'm not sure exactly what it is, but there is a difference.
Some programs can't handle a .dat renamed to .mpg, while others can.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
How to convert a bi-language VCD .dat file into a mono-langu
By pengyou in forum Video ConversionReplies: 6Last Post: 22nd Jul 2011, 10:25 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 11:34
