Hi,
I've captured trough my camcorder VHS tapes, but they are noisy.
So I captured the audio with my tuner, the format is PCM uncompressed WAV.
There is a limit of 2GB so it's splitted.
I learned that DV AVI is interleaved, audio and video separate.
I added the audio+DV AVI on Vegas timeline.
I matched the audio and deleted the noisy audio.
I rendered as DV AVI, but when I compared the new DV AVI with the old DV AVI it isn't good..
Surprised I see the rendered one is a bit darker. Why the hell does Vegas do that, I only want to replace the audio...
But during the render process vegas said no compression needed (in the preview window)
In short words, I want to replace audio without smart rendering or rendering the video.
I hope someone can help me out
Results 1 to 12 of 12
The flag once raised will never fall!
Use VirtualDub:
File -> Open Video Files (open DV AVI)
Video -> Direct Stream Copy
Audio -> Audio From Another File (select WAV file or the DV AVI you rendered with Vegas)
File -> Save as AVI
Also, how did you compare you before and after (Vegas) files? With two media players playing side by side? Even a single file being played in two players side by side may look different because one will be using the graphics card's video overlay feature, the other not (only one program at a time can use overlay). Video overlay has different color/contrast settings than the desktop. -
I opened 2 VLC.exe. I have a TV out setup, maybe that was the problem this time I will take a snapshot but first rerender...I deleted the new file..
But WAV is limited to 2GB I cant save it to an single file.
Now it's rendering here is a screenshot
I think it can be much faster, 5 minutes elapsed its 15%
How can it take that long to just replace an audio file of 2/3GB?The flag once raised will never fall! -
You can also use Graph Edit to replace the audio without affecting the video portion at all. It will be rather clunky to do on multiple files but it should be much quicker.
Let me know if you'd like more info.John Miller -
I will give it a try.
But the time is no problem for me, the only thing I scared of that it takes longer cause it's rendering the video. What do you think, that it renders the video?The flag once raised will never fall! -
Ive tried Graph Edit but it's too hard/complex for me.
It still has to write all the video data to the new file, even though it's (hopefully) just copying it.Originally Posted by Abas-Avara
If your audio is over 2GB, you must have over 3 hours of DV video to write, 40GB or more.
It also has to read the original video file while it's doing that, so maybe the time taken is not unreasonable.
What sort of HDD do you have? -
You are right, I forgot the video size of 45GBOriginally Posted by Gavino
And Ive to 2 partitions, so its a transfer of from 1 partition to the other partition..The flag once raised will never fall! -
Now I just edited the audio, how will it work with editing video (copying, cutting and pasting)? I mean with that the quality of the DV AVI
It's not yet finished, I have to compare with screenshots now.The flag once raised will never fall! -
Yes it had to do with the overlay settings.
Now Ive compared it separate with a screenshot and its ok!
Thanks everyone for the helpThe flag once raised will never fall! -
That's a worst case scenario. Not only are the reads and writes on the same drive but they are guaranteed to be far apart increasing the seek times. Putting the input and output file in different drives will increase your throughput with DV AVI.Originally Posted by Abas-Avara
Vegas is smart enough not to reencode anything with cut/copy/paste operations. Every frame of DV is self contained so they can be moved around or removed without even decompressing them.Originally Posted by Abas-Avara -
Thanks for your answer, thankgod it doesn't reencodeOriginally Posted by jagaboThe flag once raised will never fall!
Replace audio on .vob
By Flugplatz89 in forum Authoring (DVD)Replies: 18Last Post: 25th Sep 2011, 10:16 -
replace audio in a avi file.
By bigjohnny002 in forum AudioReplies: 9Last Post: 6th Dec 2009, 02:11 -
Replace audio
By quxote in forum Newbie / General discussionsReplies: 9Last Post: 9th May 2008, 02:04 -
How-to replace the audio on an AVI file
By WuTangDvD in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2007, 14:03 -
Replace audio stream in a DV AVI file
By dzoge in forum EditingReplies: 3Last Post: 6th Jun 2007, 19:57
