Can someone recommend me an FLV to AVI converter
OK: I've search this website and googled - the problem is that there's too many results
I'd like something light weight + doesn't need installing
Ideally it would be great if it was open source (I've tried searching sourceforge but am not getting any meaningful results)
In the past I've used Super - this is is great! But you need to install it
I'll go for tat if I can't get other suggestions
OM
				Results 1 to 20 of 20
	ffmpeg,
 Or I guess you want a window frontend? Then try a gui for ffmpeg like maybe WinFF, installation required but I guess you can install it and then just copy the winff folder to use it somewhere else.Code:ffmpeg -i video.flv video.avi
 And I guess you have tried FLV Extract to make an avi and mp3 from flv without reconversion.
	VirtualDub with FLV source plugin
 or
 AviSynth + VirtualDub (AviSynth requires installation)
	thank u for both replies
 ffmpeg - i'm sure i have this installed and i like using the command line!
 virtualdubmod + flv source plugin?
 yes: i like hat a lot - this would be my preferred way
 thanks!
	You may also need the correct decoders -- FLV1, VP6F, h.264, whatever your FLV file uses.Originally Posted by OM2
	oh...Originally Posted by jagabo
 where do i get those from...?
 let me know
 thanks
	ok... not sure where to start!
 virtualvub: i've downloaded latest version
 i've downloaded the plugin pack
 i've installed ffdshow and chose VFW when installing
 i try to load an flv video, but it throw an error comlaining aboout not having the right codec
 what am i doing wrong?
 virtualdub? virtualdubmod?? whats the difference? i've always used virtualdubmod
 ffmpeg
 i want to give this a go
 i've downloaded
 instructions? documentation?
 it's written in english - but it just don't male sense!!
 why is it soo hard to understand??
 i've read in other posts that ffmpeg is *reallY* powerful
 i'm intrigued to find out how to use it
 ffdshow
 i've downloaded and installed
 what is it!!!?
 launched on its own, it's not clear at all what i can do with it!
 should i create another post with all my questions!!?
 thanks
	VirtualDubMod is a revised version of VirtualDub, which handles some things better than VirtualDub. It's based on a rather old (by now) version of VirtualDub's code, however, and hasn't been updated in some time.
 ffmpeg is a command-line tool. If you're not sure how to use it, you might consider using an ffmpeg GUI like WinFF or Avanti.If cameras add ten pounds, why would people want to eat them?
	Although VirtualDubMod has a few features (multiple audio streams, crude MKV and OGM output support, saving images, etc) that VirtualDub doesn't, it is very outdated and lacks all the new features added to VirtualDub. In particular, it lacks the source filter plugin ability so it can not open FLV files directly.
	jagabo: thanks
 works now
 very happy - i'm used to virtualdubmod (so i assume i'll be ok with virtualdub)
 BUT, i get the following error reported:
 [!] Video codec "Panasonic DV CODEC" is claiming to be able to decompress
 formats that it does not actually support. This can cause the Windows
 video codec system to malfunction and may cause applications to crash.
 Please remove the errant codec or replace it with an updated version from
 the original vendor.
 i don't think this is related to the flv (or is it?)
 i wasnt aware that there was an update to the panasonic codec?
 ALSO: why aren't ALL of the formats set to libavcodec??
 let me know
 thanks
	what instances would i need virtualdubmod over virtualdub?Originally Posted by jagabo
 thanks
	i'm intrigued: i'd like to know how to use on command line - is there any advantage in knowing?Originally Posted by Ai Haibara
 or: should i just go with what u say: GUI alternatives?
 let me know
 thanks
	When you need multiple audio tracks. When you want to make outdated MKV and OGM files. When you want to quickly snapshot a few sample frames. When you have a progressive MPEG 2 video marked with 3:2 pulldown flags (VirtualDub performs the pulldown giving interlaced frames, VirtualDubMod doesn't -- although the latter can lead to A/V sync problems). When you have an interlaced YV12 source that needs processing (VirtualDub handles the chroma channels of interlaced YV12 incorrectly).Originally Posted by OM2
	jagabo: did u write virtualdub urself?
 thanks for the expert answers - that really helps
 i can't think y i would ever need virtualdubmod anymore
 question: is virtualdub being developed and updated (unlike virtualdubmod)?
	The author of VirtualDub comes out with new releases quite often. Several times a year.
	Since you're just starting out, you might want to start with the Avanti GUI. I believe it also doesn't need installing (but you'll need to supply it with a version of ffmpeg, too). Also, I think it shows you what command-line it's going to use, so you can do some research. Unfortunately, I don't know offhand of any good references for ffmpeg command-line use - I usually just use a GUI.Originally Posted by OM2
 Do you really need that codec installed? Here's what Phaeron (VirtualDub's creator) has to say about the Panasonic DV codecOriginally Posted by OM2
 (from this page in the VirtualDub forums):
 Originally Posted by PhaeronBecause ffdshow is still a work-in-progress, and everything may not necessarily work right -or even with each other. Plus, some might not want everything enabled (especially if they already have a codec handling something ffdshow does installed), or if they want to have ffdshow handle it a different way (for example, you can tell ffdshow to have the Xvid .dll(s) from the Xvid codec handle Xvid, rather than libavcodec.Originally Posted by OM2
 Besides, not everything is handled by libavcodec, anyway.
 If you want, you can keep both VirtualDubMod and VirtualDub around - they won't conflict with each other, as long as you keep both in different folders.If cameras add ten pounds, why would people want to eat them?
	Missed the Panasonic DV codec question. Get rid of it and use Cedocida instead if you need a VFW DV codec.
  Looking for a super fast converter that will handle flv-to-aviBy snafubaby in forum Video ConversionReplies: 2Last Post: 14th Nov 2010, 08:42
  looking for flv to avi converterBy videodude1966 in forum Video ConversionReplies: 4Last Post: 30th Aug 2010, 15:14
  Recommended FLV converter for PC (Not Squeeze)By Lakeshore in forum Video ConversionReplies: 5Last Post: 21st Oct 2008, 12:08
  FLV to Avi or MPG, recommended settings?By dzoni in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 16:27
  What's the best FLV converter + best method to create FLV's from pure videoBy OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 20:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
