  1. Member pchan's Avatar
    Mar 2003
    Singapore
    I am trying to encode some mkv videos to xvid using VirtualDubMod with K-lite codec(mega pack). I specify audio output as MP3 128bit in the xvid codec setting. However, the output xvid file is encoded with PCM audio. Please help comment on what I may have done wrong. Thanks.
    USA
    Maybe I'm not understanding, but you would select the audio output format in the 'Streams>Stream list' and use 'Full processing mode'. If you want to use MP3, you should also have the Lame MP3 ACM codec installed.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Have you set the audio mode to Full processing ?
    Are you sure you have set MP3 as the compression type ?
    Read my blog here.
    ANd if that wont help try avidemux, video->copy, audio->mp3 and save as a new mkv.
  5. Member pchan's Avatar
    Mar 2003
    Singapore
    Thank very much for such prompt replies.
    I am using 2 pass encoding. So, I have set the audio to full processing using Lame MP3 at the stream list in the 2nd pass ?
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    Setting the audio to Full Processing and use Lame MP3 work.
    Thank you to all.
    You folks at VH are great !
    Sep 2009
    try fairuse (LE version). simple operation to grt mp3 audio. It is free
