i need to get information from my hm200 made by jvc to sony vegas. I am having a very hard time.
software that came with camera:
the camera came with software that requires me to download itunes, and i am allowed to use the clips after i use that software. but after i am done using that software, my clips look like they came from a camera phone. yes they look that bad!
please tell me the simplest way without killing the quality.
also, i am not good with computers or software so please explain it to me like i am a two year old.
this is what kind of videos i make, i am a profesional unicyclist.
http://www.youtube.com/watch?v=zilPb9cfnJE
http://www.youtube.com/watch?v=6xSEpsjCKQ0
my computer is just a regular dell desktop bought about 4years ago.
What you want are the MTS files produced by the camera. However, those may not be easy to edit directly in Vegas.
First things first: you need to get the MTS files onto your computer. If the camera uses SD cards like I think it does, you can simply remove the SD card and put it in an SD card reader, and put that into your computer. Otherwise, if the camera offers a USB connection, you should be able to plug it into your computer (without running any additional software like iTunes) and have it appear as a new drive. Both ways, you'll be transferring the files over via Windows Explorer.
Once you've gotten the MTS files over, you can try importing them into Vegas and see how it works out. If you find (as many have) that you can import them but editing is very difficult due to choppiness and general slowness, you'll need to convert the MTS files to a less-compressed format. Soopafresh made a package to do a conversion using free tools, here:
https://forum.videohelp.com/topic346331.html
Choose "1920x1080 Same as Source". The output will be an AVI which can be easily edited in mostly any editor, at the original 1080 resolution (assuming that's what your video started at).
Note that this method will require a *lot* of free HD space, so try converting only short clips first in case you run out of space while converting a big clip.
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Sony Vegas
By Abas-Avara in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2010, 07:37 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
GZ-HM200
By FrDoe in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Aug 2009, 14:51
