DVD Lab Pro 2 & Render Motion Menu:
I'm creating animated chapter menus. I've already used Render Menu to creat the looping part of the menu. What I want is a lead in where the background is shown for half a second or so and then the chapter previews do a cross-screen intro. This is where I'm running into trouble.
If I set the "Intro Effect" option to "Cross Screen", and the time to 1 second, then the chapter previews all cross screen, but so does the image I'm using as the background. If I re-render but de-select the background, then the previews come over correctly, but it's all rendered with a black background and I'm not sure what to do with it at that point.
By "background" I really do mean "a picture that I've puy behind everything else." I tried to turn this picture into an actual "background", but found no apparent way to do that. I coud easily remove the background with a right click, but that is sort of the opposite of what I was trying to do.
I've been looking at these two how to's:
http://www.mediachance.com/dvdlab/Helppro/render.htm
http://www.mediachance.com/dvdlab/Helppro/motioncell.htm
They seem to be talking about the subject in which I am interested, but don't have the details for helping me.
Thanks!
Is there a better forum (at Videohelp or another site?) to ask this question? I thought this would be the best one.
Yes, try www.mmbforums.com which is the official forum for Mediachance products. Scroll down for DVD-Lab Pro forum.Originally Posted by xhonzi"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
FWIW, as a long time DVD Lab Pro user, I never use the built in render motion/transition tools. I find the process cumbersome and the quality average. I do all my motion assets in Vegas (any editor will do, I just happen to use Vegas), then I import these into DLP and do all my assembling. The process works much smoother, gives me a wider range of tools to work with, and produces a far better result.
Read my blog here.
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28 -
One Cell Motion Render in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2008, 10:07 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
