Hi,
I want to capture only PCM 16 bit 1500kbs 48 hz with the Avermedia software, but the funny thing is that the limit of the audio is 2GB!
My tuner is from Avermedia. Everytime there is a new problem. Why the hell would they put a limit on it?
Now I've a splitted VHS audio wich doesn't work good with joining.
Is there a bypass for this or another software?
So there is a 2GB limit on WAV files. I have videofiles with 4+ hours of PCM audio and now there is a limit on 2GB WAV PCM?
I'm getting frustated. Technologie is getting forward and now we are stuck at a 10+ years old technologie.....
The flag once raised will never fall!
Check Wikipedia - 2GB (maybe 4GB if you're lucky) is an internal structural limitation of a WAV file, not matter what software you're running - period! A videofile (as you've mentioned) is a whole different kettle of fish. You might have to record into an AVI file say & just "ignore" the video track
Avermedia avertv hd-dvr problem
By ABUELLO in forum DVB / IPTVReplies: 9Last Post: 28th Feb 2012, 23:21 -
AverMedia Avertv HD DVR. Problem.
By streetkilln in forum Capturing and VCRReplies: 3Last Post: 9th Feb 2012, 20:37 -
Avermedia capture HD using firewire?
By Zachash in forum Capturing and VCRReplies: 3Last Post: 7th Jul 2011, 16:49 -
AverMedia C027 HD Capture Low Audio
By XmnwildX12 in forum Capturing and VCRReplies: 3Last Post: 29th Jun 2011, 21:03 -
AverMedia USB HD-DVR + PS3?(need help)
By Gskyace in forum Capturing and VCRReplies: 2Last Post: 30th Apr 2011, 21:59
