I am capturing VHS tape to mpeg 2 with EasyCap and Ulead VS 10 and burning to dvd. Everything looks fine till it gets to the Philips dvd player - which plays everything else fine. Then I am getting jitter in motion scenes or when the camera pans. I have tried different resolutions and bit rates to no avail. Also used CloneDVD and Imgburn. Seems the geater bit rates exacerbate the problem. I have captured vhs before when I had a hauppauge pvr-250 and had no problems like this. Looks fine on computer.
Keep the birates below 9000 kbps and you should be fine in that area.
Post a sample here (just cut a small section of action with the problem - 1 -2 MB is enough) so we can see the issue. My suspicion is that somewhere in your process you are swapping the field order. Mpeg-2 captures are usually TFF.Read my blog here.
Bitrates are below 8K. If I capture to AVI I don't have the problem. I will try reversing the field order. It is BFF now.
Well, that did it. Field order wrong. Works great now! Many thanks!
Jerky video playback on Xbox 360 (AVStoDVD)
By KKPHM in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2010, 01:56 -
By realmfighter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Nov 2009, 01:41 -
.AVI to DVD Jerky Playback
By Bunky in forum MacReplies: 2Last Post: 27th Oct 2009, 13:23 -
help: jerky/freeze video playback after using mencoder
By keratos in forum LinuxReplies: 22Last Post: 16th Mar 2008, 13:56 -
Closed Captioning and jerky PC-based DVD video playback
By hollowman in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 09:17
