So I had a great time capturing from my STB until Time Warner Cable decided to start encrypting cable networks. Now I need a new way to record. I figure if the TV program is already on my TV, then encryption shouldn't interfere. Is there anyway from me to capture what is showing on my television?
My TV has the following slots:
Component video
HDMI
USB
S-Video 4-pin
My laptop has the following slots:
Firewire
HDMI
USB
S-Video 7-pin
Anyway to use any of that to capture my TV signal? I've read about EasyCap. Would that work in this case?
Has anything changed? Are you attempting to capture hi-def? To the best of my knowledge the signal from a standard STB to your TV is an unencrypted signal. But if your attempting to capture a hi-def picture that's a whole different ballgame. If you intend on doing the latter look at the Blackmagic cards for HDMI captures. For composite HD capture take a look @ http://www.hauppauge.com/site/products/data_hdpvr.html it captures up to 1080I.
BlackMagic Intensity cards will not capture any HDCP protected content via HDMI -- which will probably be all of the channels you can get from your cable box. The Intensity Pro will not capture analog component with the line 21 "do not copy" flag -- which will probably be most of the channels. The Hauppauge HD PVR will ignore the line 21 "do not copy" flag.
If you have a cable box, it may be possible to capture directly from the cable box via firewire to a PC. Here is some info:
http://sichantalpo.wordpress.com/2007/01/25/capture-hdtv-using-your-firewire-equipped-cable-box/
Note that the link for the drivers doesn't work as the website in the link has long been down.
Another website with some similar info is here:
http://home.comcast.net/~exdeus/stbfirewire/
The link to the drivers there works.
If this type of capture works for you, you do not need to buy a capture device. Note that some encrypted channels like HBO may not be able to be captured by this method. It costs nothing for you to try it. -
jman98, that is what I was doing. But now that TWC has encrypted a bunch of channels, I can't do that anymore.
I'm not sure about EasyCap, heard only it's not compatible with vista. Try to look at their web site if it removes all protection flags from video signal.Originally Posted by Kite
I personaly use device called "grex" (http://www.xdimax.com/grex/grex.html) to copy protected channels to DVD. You can use it with a PC capture card to record from sat box but it's more comfortable to do with any DVD recorder.
Television Set Recommendations?
By HoosierGuy in forum Newbie / General discussionsReplies: 4Last Post: 8th Feb 2011, 13:23 -
Television compatibility
By CACTUS1944 in forum DVB / IPTVReplies: 9Last Post: 23rd Nov 2009, 13:34 -
Enjoying the Death of Television
By zoobie in forum Off topicReplies: 9Last Post: 11th Mar 2009, 15:51 -
How to get video on Television
By travelingteam in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2008, 14:57 -
How do I connect my PC to my television?
By deborahlane in forum Newbie / General discussionsReplies: 18Last Post: 20th Jan 2008, 20:11
