I have an LG burner which is supposed to be a 16X burner but sometimes tries to burn at 22X, depending on which program I used to burn. This causes coasters sometimes. I would like to know if there is a registry hack, or any way to set my DVD to NEVER go above 16X speed. Most of my burning programs have a way to manually reduce the speed, but I often forget.
Zakkkkkman
I was hoping for a solution which was independant of the burning software. See, sometimes I can't use imageburn (sometimes I am running a program which has its own burner and there are other reasons too). I seem to remember a long time ago, a way to limit the burner's writing speed (maybe in the registry).
Zakkkkkman -
Maybe, but it would likely be a different registry setting for each program. A bit of a bother, but if your programs can just output the finished file to your hard drive, then you could use ImgBurn for the actual burning and control the burn speed that way.
If you want to mess about in the registry, BACK IT UP FIRST, or you may kill the OS.
Then do a search using the name of the program for a keyword and see what settings appear to be available.
Well I found out that Nero DriveSpeed is supposed to allow you to set the maximum read speed for CDs but it doesn't allow you to set the write speed. I think this is probably what I remembered. Thanks for your replies.
Zakkkkkman
Limit DVD speed permanently
By wolfvt13 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Jul 2008, 08:08 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
The best burning speed for the most compatibility with DVD players?
By gom in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:30 -
dvd burning speed
By nobbyiscool in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2007, 07:54
