Hi there
Does anyone know how to change the output folder that Scriptwriter uses when generating a joblist for VirtualDub(Mod)?
I'm trying to convert a large number of avi files from VBR->CBR audio (video direct stream copy) and want to serve the files from an external drive and copy them to the internal drive for best performance.
Slainte
midders
Volunteer for https://www.computersforkids.org.uk/
I found a workaround:
- open one of the files to be processed in VirtualDubMod
- set video and audio processing options
- open File->Job Control...
- click on Edit->Process Directory...
- choose the input and output folders
and VirtualDub does the rest.
Slainte
midders
P.S. I guess Scriptwriter isn't really required anymore?
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
Output size for cropped VOB using Cedocida/VirtualDubMod?
By BeckyD in forum Video ConversionReplies: 1Last Post: 9th Jul 2010, 10:01 -
VirtualDubMod crashes at certain output resolutions
By Kylenol in forum Video ConversionReplies: 12Last Post: 29th Sep 2009, 21:54 -
VirtualDubMod - Matroska output gets boosted height!
By Gew in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2009, 13:52
