Sometimes after demuxing VOBs with DGIndex I get two audio files, for example: WAV file 40.6MB (1536kbps, 16 bit, 2 channels, 48 kHz, PCM) and .ac3 file 11.9MB size. Which audio format better to import into TDA2? Does the WAV have better quality?
In some cases I get two ac3 files, for example: 14.1 MB [48000Hz 448 kb/s tot , 6 chnls (3/2.1) ] and 7.06 MB [ 48000Hz 224 kb/s tot , stereo (2/0) ] Is it better to import 14.1MB 6 channels file?
1. WAV may have better quality but you will probably not hear any difference.
2. Well, it depends...if you have surround system keep the 5.1 channels or if you just going to play it on stereo system is the stereo enough..... -
Watch out though,
some of those tracks could be other language or commentary tracks and you maybe inadvertantly ripped both...
That would make a HUGE difference about which one to keep.
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
