Is there any way to do both ? I did some reading & it seems possible in Virtual Dub Mod but Virtual Dub Mod is missing some filters I need to get the Video the way I want it so is there any way to encode both passes at the same time in regular Virtual Dub ? I have the bitrate I need & all of that to get the size that I want but I do not want to spend two hours on first pass just to then do 2nd pass for god knows how long
Results 1 to 11 of 11
Not sure what you mean.Originally Posted by OrchestraAndChoir
You queue the 1st pass, then add the second, then you can run it sequentially at once
You have to use 2passes if you need a specific filesize or bitrate
If you encode to a lossless intermediate first (e.g. lagarith, huffyuv, ffv1, etc..), then use that as input for the 2passes, you can speed it up if your filters are CPU heavy (because you only filter it once instead of twice) -
I added to job control a video with first pass settings then tried adding second pass & it still said statsfilenot found ?
Are you using xvid?Originally Posted by OrchestraAndChoir
It's slightly different dialog boxes for older versions of vdub, are you using 1.9.5 or newer?
Did you specify "twopass - 1st pass" for the 1st pass, file=>queue batch operation=>save as avi
and "twopass - 2nd pass" for the 2nd?, file=>queue batch operation=>save as avi
File=>job control =>start -
I am using Xvid & VirtualDub 1.8.0 & just downloaded 1.9.5 is there anything I should be aware of when encoding both avis ? Or does it do one big avi & just both passes ?
If you are using an older version the instructions are slightly different
http://wiki.digital-digest.com/index.php/VirtualDub:_Two_Pass_Encoding
If you're not doing the lossless intermediate, then just use the instructions above.is there anything I should be aware of when encoding both avis ? Or does it do one big avi & just both passes ? -
What Bitrate Calculator is the best to get the desired size ? My first encode with Virtual Dub went over size a bit I had bitrate set for 699mb but the final output was 703mb & yes I had the audio set up right as well
How do you add to queue in normal virtualdub? I want to do this too but I cannot figure out how to get jobs in job control. For the last decade or so I have been using vdubMOD which has a checkbox to
"add job for l;ater" option. How to do now on normal virtualdub?If you want to see what I've done with my videos,
check out my video work on youtube, http://www.youtube.com/user/duhmez/ -
VirtualDub 1.10.1
File > Queue batch operation > Save as AVI..
Give the file a name.
Repeat as required.
When ready to process, File > Job Control..
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 05:19 -
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 01:13 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 17:45 -
HCenc encoding problem (2nd pass)?
By ecc in forum Video ConversionReplies: 49Last Post: 29th Nov 2007, 01:22
