A little while ago, my video card (the one mentioned in the subject line) went defunct on me. It does not transmit a signal to my monitor at all whatsoever. As a result, I've been forced to downgrade to a GeForce 5500 FX, which blacks out on me if I try to keep both video cards in my PC at the same time. The 7300LE was actually shipped with my Dell XPS 410. I can't install the proper drivers for the 7300LE because it's not being detected due to not actually being present in my computer so as not to cause conflicts with the 5500 FX. What I'm wondering is what could cause the 7300LE to not be transmitting any signal? First, the DVI stopped working, and then after that the VGA portion of the card itself ceased to operate. Physically, it doesn't seem as if anything is wrong with the card, although I'm not sure if I should have cleaned beneath the heat sink and the card itself as there seemed to be some kind of ashen gray powder. In short, will my 7300LE ever work again? I am open to suggestions, hopefully none that involve frivolous expenditures.
Contact Dell for warranty service.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Composite Output Problem with Nvidia Geforce 4 Ti
By Computer Nerd Kev in forum ComputerReplies: 24Last Post: 20th Aug 2011, 18:16 -
Black and White TV Output From Nvidia Geforce 8600 GTS
By nicolasqueen in forum Media Center PC / MediaCentersReplies: 7Last Post: 24th Jan 2010, 17:40 -
NVIDIA GeForce 7300LE
By mccoady in forum ComputerReplies: 26Last Post: 18th Jun 2009, 21:22 -
NVIDIA GeForce 6100 Vs Radeon 9550
By the_importer in forum Media Center PC / MediaCentersReplies: 5Last Post: 12th Nov 2007, 16:59 -
nvidia geforce 7800gs AGP V's geforce fx 5500 AGP
By stackner in forum ComputerReplies: 5Last Post: 15th Jun 2007, 14:22
