When DVD Fab Platinum 6 wasn't loading beyind the first 70 MBs of the movie (two different computers), I opened it in SHRINK . . . and the whole movie came through like a champ!? What the . . .The problem is, I need to get it into Fab so I can customize it. So I did a backup in SHRINK, and — again, DVD Fab can't see more than 70 MBs of this movie!
I read somewhere here to try Any DVD if other programs wouldn't work; downloaded a trial; and observed the following report on this movie:
Here, on the other hand, is what is reported in DVD Fab Platinum. Note the unplayable cells.Code:Media is a DVD. Booktype: dvd-rom (version 1), Layers: 2 (opposite) Size of first Layer: 1965136 sectors (3838 MBytes) Total size: 3583694 sectors (6999 MBytes) Video DVD (or CD) label: xxxxxxxxxxxxxxxx Media is not CSS protected. Video Standard: NTSC Media is region free. RCE protection not found. Structural copy protection not found. Autorun not found on Video DVD. Bad sector protection not found. Emulating RPC-2 drive with region 1!![]()
Is the reason FAB can't see more than 70 MBs of this movie because it's dual layer? Can someone help me understand what's happening?Code:Info for folder [E:\xxxxxxxxxx\VIDEO_TS\] (DVDFab 6.0.6.0) Disc type: Video DVD Disc region: 1, 2, 3, 4, 5, 6, 7, 8 Video standard: NTSC CSS (Content Scramble System) protection is not found. RC (Region Code) protection is not found. RCE (Region Code Enhancement) protection is not found. APS (Analog Protection System) protection is not found. UOPs (User Operation Prohibitions) protection is not found. Invalid PTTs protection is not found. Invalid PGCIs protection is not found. Invalid PGCs protection is not found. Invalid TMAPs protection is not found. Invalid CELLs protection is removed! Invalid VOBUs protection is removed! Fake vts protection is not found! Bad sector protection is not found! Structure protection (ARccOS, RipGuard, etc.) is not found. PathPlayer is enabled! Unplayable cell (vts:1 title pgc:1 cell:1) is removed! Unplayable cell (vts:1 title pgc:1 cell:2) is removed! Unplayable cell (vts:1 title pgc:1 cell:3) is removed! Unplayable cell (vts:1 title pgc:1 cell:4) is removed! Unplayable cell (vts:1 title pgc:1 cell:5) is removed! Unplayable cell (vts:1 title pgc:1 cell:6) is removed! Unplayable cell (vts:1 title pgc:1 cell:7) is removed! Unplayable cell (vts:1 title pgc:1 cell:8) is removed! Unplayable cell (vts:1 title pgc:1 cell:9) is removed! Unplayable cell (vts:1 title pgc:2 cell:1) is removed! Unplayable cell (vts:1 title pgc:3 cell:1) is removed! Unplayable cell (vts:1 title pgc:4 cell:1) is removed! Unplayable cell (vts:1 title pgc:5 cell:1) is removed! 13 unplayable cells are removed!I kinda need to do this quickly. :P HELLLLLP!!
MISS CHIEVOUS
Results 1 to 13 of 13
No joy with ~.9 so I'll apparently have to store the full contents on hard drive until Fab catches up.
Meanwhile, a (usable) version rips from SHRINK containing the meat of the movie.
What do you suggest I use to pull the entire DVD down? because my SHRINK settings, er, do eliminate some bonus stuff. MrBass's DVD Decrypter? Oh wait, he wrote SHRINK lol.
er . . . I'd prefer to use a different program because then I won't have to be constantly changing my SHRINK settings. Advice?
MISS CHIEVOUSFlying around and ready to bite.
I suggest you wait until DVDFab catches up with this new protection and then use it. Seriously, are you REALLY unable to wait for this?Originally Posted by MISS CHIEVOUS
DVD Shrink hasn't been updated in years and knows nothing about the latest and greatest copy protection methods on DVD, most of which involve using bad sectors. You probably found the only movie that works on DVD Shrink (well, mostly) and not on DVDFab, but DVDFab will catch up to it. And by the way, exactly why did you not identify the movie in question? Did you not think that maybe if someone else was familiar with it, they might have some tips? All we know is that you have some mystery movie that only DVD Shrink can handle, but it can't handle the extras. -
Your responding to an issue I didn't raise, but I should probably clarify something here: I'm dealing with multiple sources, and they must of necessity each be processed differently as a result. Preferences for MrBass are preserved for one; preferences for SHRINK are preserved for the other; thus I don't have to go in and manually change them each time. I'm doing two different things with each program, the one collecting everything off of the DVD (because FAB can't see it and I don't know what's being thrown out); the other for processing a post-FAB DVD that I was able to see in FAB and did customize.Originally Posted by hech54
Yes. It's no problem; I've got plenty of drive space and I'll be monitoring FAB's betas (and others), count on it.Originally Posted by jman98
And again, your silence and refusal to name the DVD in question simply insures that anyone who might have experience with this particular title cannot help you.
Do you really think there are settings to save in either DVDFabDecrypter, DVDShrink or DVDDecrypter that willOriginally Posted by MISS CHIEVOUS
allow you to "set it and forget it" and output every DVD you throw in there exactly like you want it...exactly like the previous?
Er . . . well either I've been lucky or you're right.Originally Posted by hech54
Whatever lol.
In your brief history here you have been proven wrong AND proven to have a problem with flying off the handle before you fully understand the software.
https://forum.videohelp.com/topic372868.html#2004351
So now you are going to sit here and tell us that YOU have found a way to place two completely different DVDs into DVDFabDecrypter and end up with....for example...Movie Only with the end credits removed from both of them. YOU can save those type of settings in YOUR version of DVDFabDecrypter?...or any of them for that matter?
Originally Posted by MISS CHIEVOUS -
try this, sometimes the path player option in dvd fab wrongly sees protection on a dvd that is not there. In a few cases this then actually has the ripper removing otherwise normal content from a dvd (and a constant bug they always seem to update). Open dvd fab and on the top right click on the green check mark. Now in this new window click on the pathplayer tab and then set it to disable. Put in your disc and see if it can now see beyond 70 megs
Because if dvdshrink can rip you the main film then this points to possibly dvd fab's path player screwing up
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 15:09 -
Presence of DVD not recognized by DVDFab Platinum
By GHal in forum Newbie / General discussionsReplies: 9Last Post: 29th Oct 2008, 02:28 -
dvdfab platinum and dvd hd decrypter
By marioval in forum DVD RippingReplies: 4Last Post: 8th Jan 2008, 15:40 -
XBOX 360 converting (dvd to xvid) with dvdFAB Platinum
By devGOD in forum DVD RippingReplies: 6Last Post: 12th Dec 2007, 17:49 -
dvdfab platinum dvd to ipod audio low!!!
By Jorge in forum DVD RippingReplies: 7Last Post: 6th Sep 2007, 10:59
