I got error when tried import .m2v file into TDA 2.1.x:
"Clip GOP length is too long for a DVD-Video.
The GOP length of the clip 'XXX' in the track 'YYY' exceeds the DVD-Video standard maximum.
The DVD-Video standard maximum GOP length is ZZZ frames.
You can ignore this message if you are building an XDVD."
How to handle this issue?
And problem with another file: can no import .m2v, TDA show error that the file is incompatible. Though file format is OK, PAL.
Another question: how to get rid of the thumbnail images in a TDA menu templates? I use custom made menu which is created from the selected elements(templates), but each template in top & track menu has thumbnail image. I want just text based menu, without any images.
1. Ignore it. It will probably work fine in most players. But how are you making the m2v?
2. We need MORE information then just PAL. Are you mixing NTSC and PAL? Or are you mixing different audio or resolutions in same track? Then make separate tracks/VTS. Or else give the full details from the m2v(use mediainfo). -
Size: 204 MB (209,218 KB / 214,239,844 bytes)
Container: MPEG Elementary Video << { 1 vid }
Codec: MPEG2 Name: MPEG-2
IPBS 8% 25% 67%
BB: 2 max II: 12 max; N=12, M=3 (100%)
Pic/s: 25.000 Frames/s: 25.000 Fields/s: 50.00
Len: 3:50.000 Frms: 5,750 kbps: 7732 Qf: 0.746
pic: 720 x 576 seq ext: 4:3
sar: 1.250 (5:4) par: 1.067 (16:15) dar: 1.333 (4:3)
Resizing
1 None, already DVD format
2 None, already DVD format
But when try to import this m2v, TDA show error:
"Invalid video file.
The DVD-Video standard accepts the video formats below only.
MPEG-1 video, MPEG-2 video." -
It taken near 8 min to author dvd (12 tracks/2.09Gb), not sure has it re-encoded video or not.
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
convertxtodvd to tda
By marioval in forum Authoring (DVD)Replies: 9Last Post: 18th Jan 2008, 06:14 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
TDA 3 Questions
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 16th Aug 2007, 12:03 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
