I have divx and DVD version of the same movie.
I have only divx subtitle format(SRT).
How would I go about putting that subtitle to the DVD version?
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
wow, that's a lot of work!
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
And then you probably also need to resync the subtitles.
Another method would be to use vob2mpg on the dvd, load the mpg and srt in dvd flick or convertxtodvd and make a new dvd. -
I tried it with the method one, it is completely out of sync, not even close.
Is it worth trying other methods?"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
I'm guessing that the subs are NTSC and DVD is PAL or vice-versa. There are some subtitle utilities that claim to be able to convert timings between NTSC and PAL so maybe that would fix your problem.Originally Posted by uniks
Can someone do me a huge favor, I need to merge these 2 sub files and convert the output file to srt.
I tried merging with vobsub but can't even open them(the second one starts at 00:44:26:00)
doing this would successfully solve the problem of this topic. I guess if you know what you are doing you can have it done very fast, but it doesn't work for me for some reason.
50111.rar"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 11:45 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 12:42
