Using Nero 6 SE, had been having basically no problems until doing a recent OS reinstall - XP Media Center.
Now, I keep getting bad burns, leaving gaps on the disc surface. I've gotten maybe 2 good burns out of 8 or 10.
Tried different jumper settings, tried it on both the nid and end IDE connector. Nothing seems to improve this. It seems to read disks fine, it's recognized by the system, device manager reports no problems.
Any suggestions?
Results 1 to 19 of 19
Just ran into a bad batch of DVD media. Every burn failed. Replaced the DVDs with a different brand as all is good again.
"Quality is cool, but don't forget... Content is King!" -
Doesn't Windows Defender only look for a small handful of specific malware, and attempt to clean those? I don't remember if those particular malwares are rather rare, these days. But they still insist on keeping Defender resident...
I'll add another recommendation for Imgburn. What media/blanks are you using? (Imgburn can also tell you the media ID of those blanks...
If cameras add ten pounds, why would people want to eat them? -
Tried it, can't say I 100% understand it yet, but after getting it to burn one disc, had the same problem.Originally Posted by hech54
It just seems odd, this same burner was working fine until I did the OS reinstall. -
Do you have daemon tools installed? That could also cause burn problems. Uninstall it if you have it on your pc. Or remove the drive and install it on another pc to test it out.
Besides the above, other common problems are too many burning applications with too many access layers installed, packet writing software running/installed, incorrect ASPI layer, DMA not enabled, wrong IDE/Chipset drivers, Windows IMAPI engine enabled.Originally Posted by budz
Same burner with the same media?It just seems odd, this same burner was working fine until I did the OS reinstall.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
Re: the IMAPI engine, I looked under Admin tools, services, shows it as being manual and currently stopped, so presumably it's not an issue.other common problems are too many burning applications with too many access layers installed, packet writing software running/installed, incorrect ASPI layer, DMA not enabled, wrong IDE/Chipset drivers, Windows IMAPI engine enabled.
Nero and Imgburn are the only burning apps I've specifically installed - and ImgBurn only because it was suggested here. I guess Windows Media Player has a built-in burning utility.
Yup.Same burner with the same media?It just seems odd, this same burner was working fine until I did the OS reinstall. -
Only for CD's, also the built-in writing software is only for data. -
As I suggested remove that drive and put it in another pc to see if it does the same thing. If you don't have another pc borrow a friends/family. If that doesn't work for you as well then buy a new drive since it's so cheap these days.Originally Posted by brassplyer
Tried it in another computer, same result. Looks like it's time to play taps for it. I wonder if it was mere coincidence that it developed a problem right after the O/S reinstall. I uninstalled all the drives except the C: - maybe somehow handling it had a bad effect?Originally Posted by budz
^^^One last thing to try is buy a new 80 conductor (wire) ide cable for the drive. svc.com has one for 99 cents....not a bad deal. It could just be the ide cable that can become defective over time.
http://www.svc.com/md-24-ata-3bu.html
http://www.svc.com/md-10-ata-2cu.html
To any MOD who's online:
I think this thread should be moved to the DVD Writer section. -
Another burner works fine with the same cable connector, and it exhibits the exact same behavior on 2 different cables on another machine.Originally Posted by budz
Time to read last rites and pull the plug.
Made On Demand discs - bad burns
By oldfart13 in forum DVD RippingReplies: 5Last Post: 12th Aug 2011, 14:45 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Toshiba RD-XS35 producing a relatively high amount of bad/weird burns
By Bix in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2008, 12:25 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 14:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 04:23
