Alright I have had my JVC [GR-DVL815u] DV camcorder for months now and still can not figure out what I need to do to capture onto my PC so I can burn in mpeg1 format so I can view on my DVD player. I have Easy CD creator 5, Adobe , Ulead Video Studio basic SE.
System:
xp 1800
1gig PC2100 Mushkin
IBM 60 gig harddrive
Soyo MB (dragon plus)
Gainward Geforce 2 Ti500 (with capture abilities)
Soundblaster Audigy OEM card with Firewire port
JVC DV camcorder DVL-815 with firewire and usb connections
I have been able to capture onto avi. format using Adobe but for a 2 min file it is over a half a gig in size!! I need to be able to capture into mpeg1 or 2 format so I can view on my Toshiba 4700 DVD player. HOW do i do this?
I have Easy CD creator, Ulead basic and Adobe so I can make mpeg1 files so I can view on DVD player and not have to wear out my DV camcorder. I have a Soundblaster Audigy with a firewire port and I can view my video over the PC but cannot save it into mpeg format. Adobe states something about driver and EasY CD creator states "Cannot connect to video capture device" . What should I do?
what steps do I have to take to get video from a DV camera onto my PC so I can burn onto a CD to view in my DVD player?
Your solution is simple:
1. Get ScenalyzerLive. It captures DV from your 1394 port and even segments the file into <4 GB chunks
or
2. Use Win NT/2K/XP as your OS and NTFS as your file system. Then use DVIO as your capture program. -
I've tired ULead Video Studio 5, Media Studio 6.5 Director's Cut and Dazzle Main Actor for capturing with a Hollywood DV Bridge (looks like a camera on firewire).
ULead seems to want the Camera Off until I get that error message and only then turn on the camera (so it's sending video out via firewire). Dazzle wants the camera on before starting its capture program.
So try it both ways; maybe one will work.
Allan
Best video capture device
By sanray19 in forum Video ConversionReplies: 8Last Post: 23rd Oct 2011, 15:04 -
how to connect an old camcorder to USB capture device
By deanno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2009, 13:40 -
How to connect a USB device to an existing LAN network?
By usta in forum ComputerReplies: 14Last Post: 25th Jun 2009, 14:16 -
Pinnacle Studio is unable to connect to your video device
By Amyshubby in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 06:30 -
Can you connect a PC to a DVD HDD device?
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 11Last Post: 26th May 2008, 20:25
