    Sep 2009
    I am using the Avidemux 2.5, a really handly little program for editing stuff out of videos, but I am wondering if anyone knows if I can copy a segment from one video that I have saved in the Select AVI File folder and paste it to another video I have saved in the same folder. I was able to copy and save the segment I want to paste into the other video, but I cannot figure out how to actully paste the segment at the end of the video I want to paste the segment in. Can anyone tell me if it is even possible with Avidemux 2.5, and if it is, can you give me a simple instruction on how to do it, please? Thanks, Bs
  2. Copy the section you want and save it (e.g. "b.avi")
    Open the video you want it pasted to (e.g. "a.avi"), and use file=>append and select b.avi
    So this would put a+b together' e.g. set video & audio to copy, format to avi, then save it as "c.avi"
    Sep 2009
    Excellent, thanks for the very simple instructions. I was actually able to read along and do what you said and it worked perfectly the very first time! Thanks again. Bs
