I am a proud owner of a new and powerful computer that will be used for
home editing too.
As requested i did get 2 HD's. One 640G and the other 1TB.
each HD was devided into 2 . The C is 100G and D is the rest ~500G
while the E + F are ~500G each.
DO i put the Win [XP for now] and ALL other programs[Office plus Adobe premium set]
In the C drive and direct all workflow to F ???
I would go that way, note that C and D in one pair and E and F together are functionally single drive units, no real performance advantage gained by the partitioning. Housekeeping only. IOW, going from C to D is not as fast as going from C (or D) to E (or F).
Also, be alert to how the drive letters are assigned, the pairing may not be as expected. C will be first partition of first drive, but D may be first partition on second drive as opposed to second partition on first drive. -
I would get a small drive for the OS (80 or 160GB) and use the other two drives for storage.
C:\ = 80GB (operating system and programs)
D:\ = 640GB (capture drive)
E:\ = 1 TB (storage drive) -
Originally Posted by Dash1
Originally Posted by deadrats
Every 1tb drive i have looked at to purchase (which has been quite a few) has been 7200rpm, except one seagate barracuda which was 5900rpm.
If these are new SATA drives i would assume they are 7200's ? -
They are both 7200 rpm with 32mb mem.
The devision was done. whats the best way to go from here ? -
What Nelson37 said. OS on one drive, editing on the other. And yes, there can be "housekeeping" advantages, fragmentation comes to mind. For instance, you could have raw footage/projects on "E" and finished projects on "F", or whatever. Ephemeral files that will soon be deleted are on one partition only. Files kept intact for long-term could perhaps be stored on "D".
Make certain the assigned drive letters are as you expected. Administrative Tools -> Computer Management -> Disk Management. Change if necessary.
[EDIT] What DarrelS suggested would probably be best. I personally have no quarrel with how you've partitioned, but others will say it is less than ideal.Pull! Bang! Darn!
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06
