Hi all,
I downloaded an HD video from a web site and I'm having problems converting it to avi.
Here are details of the original video from Media Player Classic:
Video Size: 1440x1080 (AR16:9)
Video: MPEG4 (H264) 1440x536 29.97fps
One oddity that I noticed is that the video size (1440x1080) is different from the MPEG4 video info (1440x536)... Is it because it's interlaced?
When I try to convert it/scale it down to avi using either XviD4PSP or AviDemux the resultant video is cut in half... Is this also a result of it being interlaced?
What do I need to do to get the conversion to work correctly and not cut the video in half?
Any suggestions or recommendations would be greatly appreciated.
Results 1 to 10 of 10
Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
Using what tool?Originally Posted by poisondeathrayFrank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
Both xvid4psp and avidemux have deinterlace filters, as do many of the other video converters.
In xvid4psp it would be under video=>interlace/framerate
It maybe the auto generated script is incorrect or it's not auto detecting the interlace correctly, in which case you can do it manually in the script (in xvid4psp it would be avisynth=>edit filtering script)
If it's still giving you difficulties, maybe you can post a sample and we can give you more detailed instructions -
Still no luck, but I'm a novice with those two tools, so I'm flailing a bit....
Oddly, when I view the video, it's 1440x1080, but both xvid4psp and avidemux read the file as 1440x536.
These are the properties of the file from MediaInfo:
General
Complete name : C:\temp\Ueno Juri [2009.09.10].mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.04 GiB
Duration : 23mn 10s
Overall bit rate : 6 443 Kbps
Encoded date : UTC 2009-09-10 20:31:57
Tagged date : UTC 2009-09-10 20:31:57
Video
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Duration : 23mn 9s
Bit rate mode : Variable
Bit rate : 6 323 Kbps
Maximum bit rate : 16.4 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 3.582
Original display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.136
Stream size : 1.02 GiB (98%)
Writing library : x264 core 68 r1183M f21daff
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=1 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=0 / mbaff=1 / bframes=2 / b_pyramid=0 / b_adapt=0 / b_bias=0 / direct=0 / wpredb=0 / keyint=300 / keyint_min=30 / scenecut=0 / rc=crf / crf=23.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Tagged date : UTC 2009-09-10 20:33:27
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 67
Duration : 23mn 10s
Bit rate : 116 Kbps
Maximum bit rate : 198 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 19.2 MiB (2%)
Encoded date : UTC 2009-09-10 20:33:23
-----------------------------------------------------------------------------------Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face." -
Exactly.Originally Posted by poisondeathray
Here's a clip of the file: http://www.sendspace.com/file/673bfsFrank Zappa: "People wouldn't know a good movie if it smacked 'em in the face." -
Interlaced h.264 in .mp4 container isn't standard and that's what is causing problems here. Theoretically you could just re-wrap into transport stream (.ts, .m2ts) using tsmuxer and then use your usual method, but there were some bad frames doing that (might have been because your sample too small - it might have worked on a larger sample)
But one way that works for sure is to use avisynth script and feed into any encoder that accepts avs scripts and can encode to xvid/mp3/avi (e.g. xvid4psp , megui , vdub)
Install avisynth, put yadif.dll in your avisynth plugins folder, and the ffmpegsource2 package into the plugins folder (especially ffms2.avsi, and ffms2.dll) (you can get it from here http://forum.doom9.org/showthread.php?t=127037)
Change the paths/filenames to match, copy the following into a text file in notepad, save it and then rename extension to .avs from .txt. Open that .avs file in xvid4psp or other converter
Load_Stdcall_Plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
FFMpegSource2("Ueno Juri [2009.09.10]_003.mp4",atrack=-1)
Yadif(order=1) #TFF
LanczosResize(720,400)
Here is your video encoded by that method in vdub using xvid q=3
ffms2.avi
Cheers -
I figured as much...Originally Posted by poisondeathray
Don't know why the author did that... Maybe to discourage video hackers like me. :P
Thanks... A bit convoluted, but if it works, I'm not going to complain.Theoretically you could just re-wrap into transport stream (.ts, .m2ts) using tsmuxer and then use your usual method, but there were some bad frames doing that (might have been because your sample too small - it might have worked on a larger sample)
Yadif(order=1) #TFF
ffms2.avi
Cheers
Converting MP4 to AVI - Confusing Audio Problem
By visibility in forum Video ConversionReplies: 4Last Post: 29th Aug 2010, 17:02 -
Problem while converting MP4 container into avi
By Fire Foxer in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 15:55 -
Problem converting MP4 h.264 to .avi
By koala_face in forum ffmpegX general discussionReplies: 0Last Post: 12th Mar 2009, 04:47 -
Problem converting ASF to AVI/MP4
By yohu123 in forum Video ConversionReplies: 11Last Post: 16th Sep 2007, 12:24 -
Converting AVI to either MP4 ofr 3gp on Nokia 5300 phone - a/v sync problem
By johnbdrysdale in forum Video ConversionReplies: 17Last Post: 13th Jul 2007, 21:56
