My TV playbacks DivX files HD and SD including MKV files (720p/1080p) - i have many MKV files that playback but now ive got one that WONT play but its using the same audio/video codecs and resolution as my other MKV files???
can anyone explain why? it has V_MPEG/ISO/AVC video and DOLBY DIGITAL audio in a MKV container (1920x800)
and is there a MKV (1920x800) to AVI (1920x800) converter .. ?
thanks
Probably because that particular file has been encoded with settings that aren't compatible with your player (usually, too many reference frames). You can re-encode it to H.264 but with compatible settings.
You can re-encode it with compatible settings. Most programs will have presets that are compatible. You can use uncropmkv, multiavchd, ripbot264, megui....etc...
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
problems with two mkv-movies
By thenan in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Jan 2012, 17:22 -
Me And My Problems TS => MKV
By KERNEL32 in forum Video ConversionReplies: 10Last Post: 16th May 2010, 19:08 -
Having problems with MPG-HD to MKV
By SpydaMan in forum Video ConversionReplies: 10Last Post: 25th Mar 2008, 21:37
